Home > Technical > RRS Break Down
Tim Hoang
RRS Break Down
Hi, my 05 (80k)RRS TDV6 HSE broke down with all accessories lights come up on the dashboard (ABS, DSC, battery, suspension, etc) tonight. Could notr start the engine for a while, the AA came did the jump-start the engine up and told me the alternator was gone (not charging up the battery). The car was towed home. Has anyone experience this? I'd like to know if there is only alternator or major seriuos problem(s).
Thanks
Post #322225 Tue Nov 22 2011 10:02pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Re: RRS Break Down
Thanks
Reading between the lines all the lights come on when the ignition is turned on mate and if the car dont start they will remain on and the frist turn of the ignition. Alternator is a classed as consumable part I believe so i doubt ull get anything from LR due to the age of the car, might be worth a try tho. Personally is get a price from an independent for a recon alternator you might also get a few quid back on an exchange on the old one.
Post #322251 Wed Nov 23 2011 10:43am
Fairly common - 99% sure it's ether battery or alternator not charging battery. Don't worry. 2005 Zambezi TDV6 - Gone but not forgotten
Post #322270 Wed Nov 23 2011 11:45am
Tim Hoang
Hi again, anyone know where to get alternator in SE London except dealers. thanks
Post #322346 Wed Nov 23 2011 7:28pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Try Eurocarparts were £100 for my FFRR alternator, £350 cheaper than main stealer, worked perfectly Thumbs Up
Post #322372 Wed Nov 23 2011 11:34pm
Tim Hoang
New alternator fitted, everything back to normal. Thanks to all advises.
Post #322564 Fri Nov 25 2011 11:50am
