Home > In Car Electronics > Rear entertainment |
broncoupe Member Since: 24 Jul 2011 Location: dorset Posts: 61 |
Most after market systems use only headphones
Mon Nov 14 2011 6:40pm |
jetbags Member Since: 29 May 2011 Location: Margate Posts: 144 |
Had the same issue and found that the headphones had been muted on the settings screen. The icon with the head shape and headphones on will sort it out. Either that or you need to ensure you have the rosen infra red headphones and not just wireless headphones as these will not pick up a signal. Hope this helps in some small way. Jetbags 2005 Rang Rover Supercharged Loving every minute ! |
Mon Nov 28 2011 3:39pm |
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 |
have you got an AUX input 3.5mm jack at the back of the arm rest centre console bit ? near the fag lighter and 2 heater outputs
Wed Dec 28 2011 3:16pm |
