Home > General > Headlights |
sam006 Member Since: 10 Sep 2011 Location: Kent Posts: 115 |
2 ways really. The most simple is to bake the headlights in the oven for 10 to 20 mins at around 200 degrees. I'd check every couple of mins after 10 to see if the seal has become softened enough. Make sure your wearing oven gloves! The other option and the one I used (my oven was too small to fit the headlights in) is to use a heat gun with a funnelled head fitting and work your way round the headlights increasing the heat as deemed necassary. Took about 10 mins and used a spatulas to help break the seal. Before you put them back together just reheat the sealent up again.
Sun Nov 13 2011 4:43pm |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
i did the same thing on my X5 |
Sun Nov 13 2011 5:30pm |
poolie Member Since: 29 Apr 2011 Location: teeside Posts: 138 |
Im seriously thinking of doing this to change the amber reflectors. Was thinking of removing reflector then getting black vinyl stuck over them . What do you guys think??? |
Sun Nov 13 2011 6:54pm |
It would work but not sure how OEM it'd look. For the sake of £80 I'd order a set of clear or smoked reflectors off the fella in the link below
Sun Nov 13 2011 7:42pm |
Think i might just cover the reflector from outside with some black vinyl ady done it, it looks alright, well better than the amber. |
Sun Nov 13 2011 8:49pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
Nah done it and it looks,well not good it's ok from a certain angle but others you still see the amber.Also tried the tint spray which works really well but still looks rubbish(see pic)
I split it in the end,replaced with clear ones from Mike and put halos as DRL's in at the same time
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Sun Nov 13 2011 10:31pm |
Loving the halo's You've got me fancying installing those on mine now as well!! Range Rover Sport HSE and for a bit of weekend fun a S1 Lotus Elise with a few track biased additions! |
Sun Nov 13 2011 10:43pm |
Cheers,they are LED's it does'nt really show in the picture,very close,if not my favourite mod. Gets plenty of looks off other RRS drivers |
Sun Nov 13 2011 10:53pm |
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 |
To much like BMW for my liking, if I wanted that then would have stuck with the X5?
Sun Nov 13 2011 10:58pm |
You see the individual Led's on mine,its just the camera on the I phone stuggles with the light,thats why it looks like one ring of light.
Sun Nov 13 2011 11:20pm |
1066 Member Since: 15 Jul 2011 Location: hastings Posts: 17 |
hi all
Tue Nov 15 2011 2:20pm |
broncoupe Member Since: 24 Jul 2011 Location: dorset Posts: 61 |
Thanks for suggestions grabbed the hot air gun 10 minutes later headlamp stripped for the installation of strobe bulb
Mon Nov 21 2011 7:16pm |
Contact phil@ca-at.co.uk regarding the Halo LED kit (They will have to import a pair of 106mm & 120mm Orion v2 Lites) The internals (after splitting) just need to be sprayed matt black No effect on the lights at all, you do not paint the reflectors The clear side reflectors can be sourced from Mike Stefan (USA member) and a link to his mod canbe found here http://www.rangerovers.net/forum/viewtopic...p;start=15 RRS gone Audi SQ5...Gone Audi Q7 S-Line 240 3.0TDI Gone Audi A6 Allroad Sport 270 3.0TDI |
Tue Nov 22 2011 8:51am |
