Home > General > Headlights
broncoupe
Headlights
I was wondering has anyone successfully separated the front headlamp glass from the headlamp unit
If so is there any special way to do this
thanks
Post #320998 Sun Nov 13 2011 4:35pm
sam006
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
2 ways really. The most simple is to bake the headlights in the oven for 10 to 20 mins at around 200 degrees. I'd check every couple of mins after 10 to see if the seal has become softened enough. Make sure your wearing oven gloves! The other option and the one I used (my oven was too small to fit the headlights in) is to use a heat gun with a funnelled head fitting and work your way round the headlights increasing the heat as deemed necassary. Took about 10 mins and used a spatulas to help break the seal. Before you put them back together just reheat the sealent up again.
Just make sure before you put them back together you've not left any finger prints on the inside of the lense! Made that mistake before myself when splitting an old x5's lights to remove the orange reflectors.
Should be a fairly simple job but I'd make sure you take your time as rushing it can make it more stressful than necassary!! Range Rover Sport HSE and for a bit of weekend fun a S1 Lotus Elise with a few track biased additions!
Post #321005 Sun Nov 13 2011 5:43pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
i did the same thing on my X5 Laughing
Post #321022 Sun Nov 13 2011 6:30pm
poolie
2006 Range Rover Sport TDV6 HST Java Black
Im seriously thinking of doing this to change the amber reflectors. Was thinking of removing reflector then getting black vinyl stuck over them . What do you guys think???
Post #321036 Sun Nov 13 2011 7:54pm
sam006
It would work but not sure how OEM it'd look. For the sake of £80 I'd order a set of clear or smoked reflectors off the fella in the link below
http://www.rrsport.co.uk/forum/topic22760....reflectors
Got mine off him and very impressed Range Rover Sport HSE and for a bit of weekend fun a S1 Lotus Elise with a few track biased additions!
Post #321047 Sun Nov 13 2011 8:42pm
poolie
Think i might just cover the reflector from outside with some black vinyl ady done it, it looks alright, well better than the amber.
Post #321058 Sun Nov 13 2011 9:49pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Nah done it and it looks,well not good Whistle it's ok from a certain angle but others you still see the amber.Also tried the tint spray which works really well but still looks rubbish(see pic)
I split it in the end,replaced with clear ones from Mike Thumbs Up and put halos as DRL's in at the same time Very Happy
Post #321076 Sun Nov 13 2011 11:31pm
sam006
Loving the halo's Cool You've got me fancying installing those on mine now as well!! Range Rover Sport HSE and for a bit of weekend fun a S1 Lotus Elise with a few track biased additions!
Post #321077 Sun Nov 13 2011 11:43pm
mrfixit
Cheers,they are LED's it does'nt really show in the picture,very close,if not my favourite mod. Thumbs Up Gets plenty of looks off other RRS drivers Wink
Post #321078 Sun Nov 13 2011 11:53pm
timcom0
To much like BMW for my liking, if I wanted that then would have stuck with the X5?
But if someone could fit 51 individual led's into the pattern in the housing, that would be some daylight running lense, thinking of trying it, but total 102 led's have to think of power, drilling etc.
What do you think?
You see the pattern between side light and full light?
Post #321079 Sun Nov 13 2011 11:58pm
mrfixit
You see the individual Led's on mine,its just the camera on the I phone stuggles with the light,thats why it looks like one ring of light.
Just sank in what and where you meant. Wink
Post #321080 Mon Nov 14 2011 12:20am
1066
United Kingdom 2005 Range Rover Sport TDV6 HSE Buckingham Blue
leds reflectos
hi all
want to do the same as mr fixit hs done to his range rover
were do i get the leds and did you spray or hand paint inside the lamp case
what did you use to fix leds and lamp lens
does it mess the headlight beam up ?
were do i get clear reflectors from are they legal
Post #321271 Tue Nov 15 2011 3:20pm
broncoupe
Thanks for suggestions grabbed the hot air gun 10 minutes later headlamp stripped for the installation of strobe bulb
I will try and post a picture Thumbs Up
Post #322008 Mon Nov 21 2011 8:16pm
Re: leds reflectos
1066 wrote:
hi all
Contact phil@ca-at.co.uk regarding the Halo LED kit (They will have to import a pair of 106mm & 120mm Orion v2 Lites)
The internals (after splitting) just need to be sprayed matt black
No effect on the lights at all, you do not paint the reflectors
The clear side reflectors can be sourced from Mike Stefan (USA member) and a link to his mod canbe found here
http://www.rangerovers.net/forum/viewtopic...p;start=15
Thumbs Up RRS gone
Post #322059 Tue Nov 22 2011 9:51am
