Home > Faults & Fixes > Anti roll bar stabilizer
buster11
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I collected my car from my dealer today - a great independent one, who advised me that the anti roll bar stabilizer had a slight oil leak. This part I understand dampens the car when going around a corner, and uses oil to do so.
Evidently the leak is not serious at the moment, so he has has wiped it down topped up the oil etc. However he did indicate that it will need resolving in due course. Whilst it would appear that the part could be removed and new seals fitted thereby resolving this issue, a seal kit is not available - so a new part is £809 plus fitting.
The car is out of warranty at the moment, but only has 35k on it, so I contacted LR to see if they would help with the cost - nodding and scraping - acknowledging that they have no liability etc Bow down . They were fairly curt with me and said that they wouldn't. My argument which fell on deaf ears is that the part really shouldn't be failing after 35k and 4 years, I'm not particularly surprised by this, and accept that at then end of the day i'll end up paying for it - but if you dont ask !
I just wondered if anyone else has had experience of this, and if there are any cheaper alternatives to a completely new part ? Any help or advice would be appreciated.
Post #320824 Fri Nov 11 2011 4:53pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
I assume its the rear one , sure the front is 1200 + vat
Its a chassis off job to do it as well , takes power steering fluid topped up from the engine bay Thumbs Up
Post #320851 Fri Nov 11 2011 8:09pm
Bobby
Similar issue here...might be helpful
http://www.rrsport.co.uk/forum/topic19778.html Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #320855 Fri Nov 11 2011 8:40pm
Supacat
For the sort of money a new part is, it must be worth taking the old part off and seeing if there is a commercially available seal available or whether a new pattern gasket can be made up.
Anyone got an exploded parts type picure of said item?
Post #320985 Sun Nov 13 2011 11:56am
x5pea
effort involved to get it off mate, id be wanting to fit a new part, last thing you want is to have to replace it
Post #321023 Sun Nov 13 2011 5:33pm
Supacat
X5pea - blindly fitting a new part at less than 20k miles, which is what mine did, without knowing what actually failed, seems madness. If it was not under warranty I'd want some root cause analysis to confirm I wouldn't be having a groundhog day in the near future.
Post #321500 Thu Nov 17 2011 6:54am
x5pea
Fitting a new part is exactly what i would want, they arent all failing at 20k, infact some are lasting till over 100k. By all means investigate what failed if your interested in forcing LR hand on the matter but it would be madness to start to solutionise a fix given the effort (cost) required to remove the ARB.
If the car is within warranty i cant see why the ARB wouldnt be covered
Post #321517 Thu Nov 17 2011 8:32am
