![]() | Home > Faults & Fixes > Anti roll bar stabilizer |
buster11 Member Since: 15 Jan 2010 Location: Brighton Posts: 32 ![]() ![]() ![]() |
I collected my car from my dealer today - a great independent one, who advised me that the anti roll bar stabilizer had a slight oil leak. This part I understand dampens the car when going around a corner, and uses oil to do so.
Similar issue here...might be helpful
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
For the sort of money a new part is, it must be worth taking the old part off and seeing if there is a commercially available seal available or whether a new pattern gasket can be made up.
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
effort involved to get it off mate, id be wanting to fit a new part, last thing you want is to have to replace it |
X5pea - blindly fitting a new part at less than 20k miles, which is what mine did, without knowing what actually failed, seems madness. If it was not under warranty I'd want some root cause analysis to confirm I wouldn't be having a groundhog day in the near future. |
Fitting a new part is exactly what i would want, they arent all failing at 20k, infact some are lasting till over 100k. By all means investigate what failed if your interested in forcing LR hand on the matter but it would be madness to start to solutionise a fix given the effort (cost) required to remove the ARB. If the car is within warranty i cant see why the ARB wouldnt be covered |
