Home > Tips & Tricks > Seat Belt Chime Disable |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
Not so much a fault but for the seatbelt 'bongs' you can deactivate by turning on ignitition to level 1 (i.e. not start the engine) then put the drivers seatbelt in and out 9 times, then you should here a 'bong bong' to confirm it has done.
Fri Nov 11 2011 9:39am |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
This is more a Tip or Trick, so moved to that forum. And it's been posted before http://www.rrsport.co.uk/forum/topic5753.html
Fri Nov 11 2011 10:02am |
Do you know if it works on new models Martin? I'll give it a whirl later |
Fri Nov 11 2011 10:21am |
I don't, so some info on yes/no would be good Like this site? Buy some RRSPORT goodies to show your support! |
Fri Nov 11 2011 10:29am |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
it worked on my 56 reg and also on my 59 facelift one
Fri Nov 11 2011 10:39am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
The gonger I want killed is the key in ignition with door open gonger. Sometimes it lasts forever but other times only for 60 secs.
Fri Nov 11 2011 12:23pm |
Garry, Stop driving with your door open.........it's dangerous |
Fri Nov 11 2011 12:41pm |
essexfarmer Member Since: 28 Aug 2011 Location: Essex Posts: 108 |
I disabled the seat belt chime on my 2012MY as soon as I got it, so yes you can still disable it. 12MY RRS Orkney Grey HSE Lux
Fri Nov 11 2011 1:25pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Thanks essexfarmer ON THE WAY: BMW F21 M140i
Fri Nov 11 2011 1:42pm |
nathanh1 Member Since: 03 Aug 2010 Location: Southampton Posts: 151 |
+1 |
Fri Nov 11 2011 4:27pm |
Jeeeppy Member Since: 17 Jun 2011 Location: Garden of England Posts: 39 |
Turned mine off last night Thanks for tip |
Sun Nov 13 2011 9:19pm |
SONYBOY Member Since: 22 Dec 2010 Location: East Of England Posts: 70 |
How do you get it back ? 2007 COOLRRS |
Thu Nov 17 2011 4:57pm |
repeat the process |
Thu Nov 17 2011 4:58pm |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
I've just done this because I've had a dog on the front seat (canine variety!) for the past week and he was setting it off. Does the red warning light still stay on until you put your seat belt in |
Thu Nov 17 2011 5:40pm |
