Home > General > vibrating dipped beam..now doing my swede in |
Well after thinking it was the tyre balance out (now sorted) I'm back to square one with the vibrating dipped beam.
Tue Nov 01 2011 2:36pm |
do you get any steering wheel wobble?
Tue Nov 01 2011 3:04pm |
GrantyBoy Member Since: 21 Oct 2011 Location: Aberdeen Posts: 17 |
very slight at 65mph and over |
Tue Nov 01 2011 3:05pm |
I was hoping mine was no longer wheel related... RRS gone
Tue Nov 01 2011 3:06pm |
do you have any vibration? Could be you've whacked an alloy as well? |
Tue Nov 01 2011 3:27pm |
ever so slight a wobble at 60ish... not anything that you notice unless you let go of the wheel... RRS gone
Tue Nov 01 2011 3:48pm |
sounds the same as me |
Tue Nov 01 2011 3:49pm |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 |
It could just be rim/tyre inbalance - would suggest to start with proper wheel balancing. This includes taking the tyre of the rear/front lip of the rim. If this does not help then swap your front and rear wheels (ideally rims only). This will show if your wheels are really buckled.
Tue Nov 01 2011 4:17pm |
yeah..looks like a trip to a different wheel balancer is on the cards than... they took them 3 go's to get these as good as they are RRS gone
Tue Nov 01 2011 5:07pm |
