Home > General > vibrating dipped beam..now doing my swede in
Well after thinking it was the tyre balance out (now sorted) I'm back to square one with the vibrating dipped beam.
It seams to be the near side unit that's the culprit, with a shimmering edge that is very obvious on motorway signs after dark...
Is there anything in these units that can come lose... allowing the xenon bulb to move too freely?
it's getting to the point I'm going to have to replace the whole head unit to sort it (before i do my angel eye headlight mod )
Does nobody else notice the effect when on the motorway? RRS gone
Post #319656 Tue Nov 01 2011 2:36pm
GrantyBoy
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
my car is doing the same. Been told by Land Rover that I have slightly buckled the OSF alloy and this is what's causing it.
Post #319663 Tue Nov 01 2011 2:57pm
do you get any steering wheel wobble?
(interesting it's the same age/model and err colour....you sure yours is not Java? ) RRS gone
Post #319664 Tue Nov 01 2011 3:04pm
GrantyBoy
very slight at 65mph and over
Post #319665 Tue Nov 01 2011 3:05pm
I was hoping mine was no longer wheel related... Censored RRS gone
Post #319666 Tue Nov 01 2011 3:06pm
GrantyBoy
do you have any vibration? Could be you've whacked an alloy as well?
Post #319669 Tue Nov 01 2011 3:27pm
ever so slight a wobble at 60ish... not anything that you notice unless you let go of the wheel... RRS gone
Post #319676 Tue Nov 01 2011 3:48pm
GrantyBoy
sounds the same as me
Post #319678 Tue Nov 01 2011 3:49pm
C10KO
It could just be rim/tyre inbalance - would suggest to start with proper wheel balancing. This includes taking the tyre of the rear/front lip of the rim. If this does not help then swap your front and rear wheels (ideally rims only). This will show if your wheels are really buckled.
I had gone through the same and ended up swapping the wheels with a friend. He had the wheels refurbished and never experienced any vibration Shocked
Post #319686 Tue Nov 01 2011 4:17pm
yeah..looks like a trip to a different wheel balancer is on the cards than... they took them 3 go's to get these as good as they are Laughing RRS gone
Post #319695 Tue Nov 01 2011 5:07pm
