Home > General > Bit of help with brakes please |
Thats the sort of answer i'd expect from you dill, considering the hadbrake shoes were only changed 8000 miles ago i did not expect these to be worn out, and seen as i never use the handbrake i don't think that they will be wearing out in the near future either, as for the time it took to replace the rear brakes, it was for reference only to give others an idea how long it is likely to take them to do theirs and not for stupid comments like you have just posted. As you will see, i am here to help other members on here, unlike you with ALL your negative comments you keep posting, Last edited by Ady 555 on Mon Oct 31 2011 9:50am. Edited 1 time in total |
Mon Oct 31 2011 8:55am |
Like i said above dill, i am here to help others if i can, this is a public forum and i am not here to argue the toss with you on every subject i comment on, What is your problem, pm me if you wish. |
Mon Oct 31 2011 9:21am |
Your right i don't, but the difference is...... I am willing to help, but with comments like you keep making, i sometimes wonder, why i bother So stevee, back on topic, sorry mate, you should have all the information you asked for now i think. If you require anymore information just as dill, |
Mon Oct 31 2011 10:39am |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Surely the whole point of the sensor being a seperate part is that it doesn't need to be changed with the pads unless you have worn them down to the point that the wear indicator light comes on?
Mon Oct 31 2011 9:05pm |
Dill obviously dosn't understand the idea of the pad sensor, its not a case of cutting corners, its a case of knowing what you are doing and the reasons why. As i said i had a new pad sensor to change but there was nothing wrong with the old one because i changed my pads before they had worn out. I could of got another 12 months out of my rear discs but seen as i was changing the pads i thought i might aswel change the discs at the same time. (cutting corners false economy ) |
Tue Nov 01 2011 8:53am |
Obviously your knowledge of brakes is far less than mine, but i don't have a problem with that, we learn something new every day Its not about point scoring either, its about sharing your experiences on the subject in this case brakes, to help others replace theirs, but as usual you have to stick your nose in with sarcastic comments which don't help anyone. I am going to end this subject now because you are beginning to bore me. |
Tue Nov 01 2011 9:42am |
You can always give this a look through......
Tue Nov 01 2011 9:52am |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
Guys (Ady/Dill) please keep it civil - people have different ways of doing things so please respect that even if you don't fully agree. Like this site? Buy some RRSPORT goodies to show your support! |
Tue Nov 01 2011 11:44am |
steveee Member Since: 03 May 2011 Location: orpington Posts: 34 |
ah martin , let them fight it out ! i am off work with a bad back and its given me a bit of entertainment (lol) . by the way discs and pads being fitted in my garage at the moment.
Tue Nov 01 2011 3:31pm |
