Home > General > Can Anyone Advise Me Please On Accessing The Seat Back ??
alymac
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
Good afternoon everyone, i am in the process of fitting rear headrest dvd screens to the car, its the rosen type system where you feed the cables through the seat back and collect them at the bottom but i can`t find a way to retrieve the cables. I was hoping someone here has had a similar job done and can advise me on how to get into the cables, do you use force to pull the bottom of the seat back ?? Big Cry
Many thanks in advance to anyone that can help me Bow down
Alasdair
Post #253680 Thu Feb 04 2010 3:27pm
benjcpaul
Hi Alymac,
Did you manage to solve this issue? I am dealing with the exact same problem and cannot seem to find a way to unclip the bottom of the front seats?
Any tips would be appreciated.
Thanks
Post #319326 Sun Oct 30 2011 8:28pm
Bobby, where are you Question Question
Post #319338 Sun Oct 30 2011 9:34pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Why unclip anything?just recline the seat 50% then use a fisher rod.I only say recline it so that you don't catch the roof lining with the rod. Thumbs Up
Post #319339 Sun Oct 30 2011 9:51pm
Bobby
Could you do it if you took the Front Seat Backrest Cover off? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #319344 Sun Oct 30 2011 11:27pm
benjcpaul
Have tried a curtain wire, but can't seem to find the path through the seat...plus the bottom of the seat is clipped together pretty firmly...
Thanks Bobby - Note 9. On your instructions looks like the way forward.... Now just need to locate the 5 clips? and tension straps? Diagram seems overly straight forward, am sure it wasn't that simple when I looked at the actual seat...
Has anyone actually done this?
cheers
Post #319367 Mon Oct 31 2011 9:58am
mrfixit
From Memory I think if you go down the left hole when sat in the back it goes straight down easily.I've done 4 vehicles now all via this method with no problem at all and saves all the undoing of fittings and such.The fish rods I use are fibreglass so maybe they find the route easier.
Post #319400 Mon Oct 31 2011 1:37pm
benjcpaul
Cheers MrFixit, managed to unhook the bottom plastic clips with a screwdriver and then reach up through the seat to meet the wire....Agreed the left side hole is much easier to feed down than the right, but managed to complete both....
I have temporarily hooked the dvd power to the cigarette lighter and they work great.... the units also have the ability to hook directly into the car's battery with +ve & -ve connectors - IS there an easy place to tap into the car's power under the seat? Really want to keep the wire's "on show" to a minimum, so if I can avoid using the cigarette lighter that would be great....
Many thanks
Post #319457 Mon Oct 31 2011 7:35pm
