Home > Technical > Engine management failure, system shutdown!!! |
sam006 Member Since: 10 Sep 2011 Location: Kent Posts: 115 |
Have been to a specialist this morning to try and sort the issue. Fault code came up as PO299-00 turbo under boost.
Wed Oct 26 2011 11:29am |
dazzagt Member Since: 07 Jul 2011 Location: London / Wokingham Posts: 231 |
Sorry to hear mate, never good when the 4 wheel chariots are playing silly .. hope you get it sorted and it's not too £££ RRS S/C, Factory Fitted Full HST kit, 22" Overfinch SS, Carbon Vents & Grill .. - FOR SALE - PM me for details
Wed Oct 26 2011 11:59am |
essexfarmer Member Since: 28 Aug 2011 Location: Essex Posts: 108 |
Not sure if this is at all helpful Sam but we have had a very similar problem with two of our John Deere tractors this year. Lots of error codes and engine power being de-rated messages (the tractor version of limp home mode I guess). It turned out to be the variable vanes sticking in the turbos, now I am not sure if you can even get to the turbo on the sport, or even if you would want to, but our problem was 'cured' by a bloody good dose of WD40 sprayed in the (cold) turbo while the external rod was moved backwards and forwards. I hasten to add that this 'fix' was carried out by the dealership and not by me and to be honest I half expect the problem to come back again. 12MY RRS Orkney Grey HSE Lux
Wed Oct 26 2011 4:10pm |
Cheers Dazzagt, more annoyed that it occurred once I spent the last month colour coding and refurbing wheels and having the paintwork sorted!
Wed Oct 26 2011 7:16pm |
Problem continued (car went into limp mode 5 times on a trip to Norfolk from Kent) so dropped it off last Friday to AHL Engineering, Maidstone for a fault finding excercise. Turned out it was an inter cooler issue. Had been damaged at some point. Replacement £120! A damn site less than the £2k to £4k it could have cost to change the turbo!!
Thu Nov 17 2011 10:10pm |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 |
Do yourself favour and go over to the D3 site as this is a common problem over there, no need to take the body off and someone will advise of a place to have your car fixed. |
Thu Nov 17 2011 11:21pm |
You're right - P029900 Turbocharger/Supercharger Underboost Condition.
Thu Nov 17 2011 11:35pm |
rangehelper Member Since: 17 Nov 2011 Location: Moscow Posts: 4 |
In Russia, a lot of cars with the problem of turbine engine 3.6 liters. Of practice should be that the car can not stand without moving for over a week. As soon as the car stood for more than there is a problem - LIMITATION OF DUTY - ENGINE failed. Often have to change both the turbine. Replacement is the removal of the body from the chassis. The cost of repairs 4000-4500 pounds. |
Fri Nov 18 2011 11:31am |
Turned out that the turbo was ok, had the MAP sensor cleaned first, still faults showing. Then engine management reprogrammed with the latest software, again fault appearing after a run. Finally had the engine tray removed and on investigation found that the inter cooler was damaged.
Fri Nov 18 2011 8:09pm |
Malaysia Boleh!
Fri Nov 18 2011 9:00pm |
RRS_STEF Member Since: 21 Sep 2014 Location: london Posts: 2 |
My rrs is kicking out black soot when I put my foot down in been told it's my turbo ain't sure where to go to get this looked at other than range rover which will charge me half a mill ps I live in LONDON. |
Tue Sep 23 2014 11:00pm |
