Home > Technical > no sat nav lady sounds
United Kingdom 2005 Range Rover Sport TDV6 HSE Buckingham Blue
hi all
just updated my 05 sat nav to 2011 tried it on a trip to thorpe park
only thing missing was miss money penny saying left next juntion etc
found at bottom right of screen a nav screen with a red x across it?
how can i enable sounds on the sat nav
i also found that the bloo tooth does not pair ?
anymore any ideas thanks
Post #318370 Fri Oct 21 2011 9:18pm
You need to go into you satnav settings for the sound settings, then uncross the sound and then it should work Thumbs Up
Bluetooth, Whilst in the car try switching your phone off then back on again, go into your bluetooth settings then press search it should then pair up with land rover, if it asks you for a pin then put in 2121 Thumbs Up
Post #318372 Fri Oct 21 2011 9:26pm
toshers
Scotland 2008 Range Rover Sport TDV8 HSE Stornoway Grey
There are issues pairing with some Blackberry models, it most often fails to connect. There is a work around over on the D3 site but it's still a major PITA!
Post #318384 Sat Oct 22 2011 6:20am
1066
thanks ady panic over did as text and ok
Post #318488 Sun Oct 23 2011 5:50pm
Nice one Thumbs Up
Martin, will you move this to faults and fixes please, many thanks Thumbs Up
Post #318489 Sun Oct 23 2011 6:02pm
