Home > Technical > Adaptive Headlights |
I think you don't have ADAPTIVE FRONT LIGHTING SYSTEM (AFS).
Fri Oct 14 2011 9:14am |
essexfarmer Member Since: 28 Aug 2011 Location: Essex Posts: 108 |
Thanks for the reply Bobby, I rather hope I do have the adaptive system as I speced it when I ordered the car and paid the extra for it, also the garage that supplied the car seem to think it should be there but I feel, like you, that it should go through the initialization process when they are switched on. The garage informed me that they 'don't think' the latest system does this.
Fri Oct 14 2011 9:23am |
Well, I've not even seen a 2012MY RRS but I would think the adaptive headlights should function the same!!
Fri Oct 14 2011 10:36am |
V8 HSE CRUSADER Member Since: 02 Oct 2011 Location: driffield Posts: 163 |
My 2008 has adaptive lights they calibrate every time I switch on V8 HSE CRUSADER 2008
Fri Oct 14 2011 7:54pm |
Mr H Member Since: 09 Sep 2011 Location: Lincs Posts: 427 |
Think he's asking bout the my12 chap Have i got the busted controller?!?!!? 2009 RRS TDV8 Santorini Black Ivory / Anigre Privacy DVD & TV Side Steps |
Fri Oct 14 2011 9:20pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 |
My AB doesn't do the look left, down, right, up on startup (my old 06 HST did). |
Wed Oct 19 2011 9:44pm |
Thanks phil and everyone else, the garage checked the lights on monday and tell me they are working fine, I have now had more of a chance to try them myself and they do work but not as well as on my old disco and as phil says the don't go through the old calibration anymore, shame really I quite like that feature. 12MY RRS Orkney Grey HSE Lux
Thu Oct 20 2011 7:03am |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
Noticed my 2010 model does not "appear" to have the adaptive headlights. Both the startup calibration and the obvious bending on tight turns that my 2008 model had.
Sun Oct 23 2011 11:12am |
Not an RRS but my Evoque has the AFS and it also doesn't do the headlight dance or recalibration like my RRS did. To tell that you have the AFS you should get an additional icon on the dash to on start up and when moving at less than 35mph and either use the indicator or turn the wheel the cornering spot light should come on in the direction you are turning. Something else I have noticed is that I get not vibration visible in the reflections from road signs at night like I used to with the RRS 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Oct 23 2011 1:48pm |
Tim - I'd forgotten about the vibrating lights on my old one - a major benefit on either having the new system or maybe not having them... |
Sat Oct 29 2011 1:33pm |
But you can notice you have them if you have them......certainly on the pre 10 models you can anyway Have i got the busted controller?!?!!? 2009 RRS TDV8 Santorini Black Ivory / Anigre Privacy DVD & TV Side Steps |
Sat Oct 29 2011 4:34pm |
