Home > Technical > Park Brake
Jonnylp
Park Brake
My sport has started making a loud screeching type sound when trying to apply the EPB.
It happens intermittently and after a few attempts switching EPB off and on it Serbs to be ok.
Anyone have any idea what could cause this ? Could it be dirt or grime ?
Is this something that needs a dealer to look at or a good independent ?
Any suggestions are welcome.
Thanks in advance !!
Post #317653 Mon Oct 17 2011 9:24am
RRS_PAT
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Seems to be a common problem Sad Mine does it intermittantly and applying the brake whilst moving seems to cure it. I think it is either dirt in the brake which gets compressed (especially when left on whilst car is parked) or mis alignment. I was told about £200 to clean the brakes, but the dealer thought that it probably wasn't worth doing this until the pads needed replacing.
This might help
http://www.rrsport.co.uk/forum/topic10316....pb+screech 2011 Autobiography Santorini Black
Post #317655 Mon Oct 17 2011 9:31am
Jonnylp
Thanks very much, sounds exactly the problem.
Will wait and see if it gets worse or a more frequent occurance.
Cheers !!
Post #317658 Mon Oct 17 2011 10:03am
raadar
Australia
same problem on mine has been cured by cleaning out the park brake drums (which was done under warranty). The technician advised that re-setting the drum after removing it is a difficult process, without the correct tools, to get right and should only be attempted by the dealer. He did show me, however, the holes in the sides of the rear hub/park brake drum which can be used for regular flushing of the brake drum with pressurised water to keep it generally clear of dirt build up...... a necessity if you use the vehicle for offroading in muddy or sandy environments.
Don't forget to dry the brakes out afterwards to prevent buildup of corrosion.
hope this helps..................frank my10D4se3Ltdv6 current
my08RRStdv8 sold
my07RRStdv8 sold
Post #317756 Tue Oct 18 2011 12:01am
Jonnylp
Thanks Frank - all advise / tops is greatly appreciated.
Regards
Post #317790 Tue Oct 18 2011 12:15pm
Martin
Site Administrator & Owner
Don't wait! Get it looked at or you could damage the EPB actuator which is a heap of money to replace.
Have the rear EPB shoes replaced (possibly with the disks) and the whole lot adjusted. Like this site? Buy some RRSPORT goodies to show your support!
Post #317800 Tue Oct 18 2011 1:20pm
bootz
I had this on my 57 TDV8 RRS; a god awful screeching sound with no warning, when i applied the EPB. This happened on three occasions and was worse each time. The fourth application and i thought the back axle had broken in two Shocked . The noise was horrendous. A call to the dealer and i was advised to get the car in pronto. All fixed in two days under warranty, thanks TH White Thumbs Up - another 'well known problem'...not to me it wasn't! No problems at all after that - but as Martin said best get it looked at quick.
Post #317999 Wed Oct 19 2011 10:14pm
Jonnylp
Cheers will get it in asap, appreciate your advice. Thumbs Up
Post #318092 Thu Oct 20 2011 3:43pm
