![]() | Home > General > Battery Location |
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 ![]() ![]() |
Thanks for that.
Wait at least 2 minutes for the electronics to shut down.
gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542 ![]() ![]() ![]() |
When I had a slight issue at the start of the year when the car went in to limp mode (didn't use it for a couple of weeks) and LR Assist came out they connected the + and - together after removing from the battery for a couple of minutes, they said this was a "hard reset"? It's been fine ever since |
Well I have disconnected my battery today for 5 mins to try and do a hard reset in the hope of clearing this intermittent suspension fault.
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
is there an error code or particular message? are there any other symptoms? ============
Hello,
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 ![]() ![]() |
Brake pedal switch or brake light bulb....does it happen more when braking....? |
No it isnt linked it braking, you can just be driving a long and it just pops up on the dash.
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 ![]() ![]() ![]() |
You need to get the fault code read and cleared properly, rather than just carrying on driving it. Give Armson AE in Syston a call, he'll read it for not many £'s and likely be able to sort it.
