Home > General > maximum size of USB in MY10
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
does anyone know the maximum size for the USB stick when connected to the audio system in MY10? ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #313011 Fri Sep 09 2011 3:52pm
Gerico
Physical size of the connector should be standard (and actual sticks come in all sorts of shapes and sizes) so I can only assume you mean the actual memory size. In theory this should be limitless. Question
To test you could connect an external drive with a USB cable and see what happens!
Not a lot of help I know but I'd be intrested to see what people have actually used.
Richard
Post #313016 Fri Sep 09 2011 5:15pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Think a lot of cars struggle with anything over 4gb
Post #313017 Fri Sep 09 2011 5:28pm
mse
Mines at least 8gb it could be 16gb and fine.
Micro USB as well so its hardly noticable Mike
2014 Facelift Discovery
Post #313022 Fri Sep 09 2011 5:59pm
rrsboy
yep that's my question.. systems struggle because of the file allocation table size. Would you mind confirming if your 16gb works? I am about to order some new sticks Thumbs Up ============
Post #313069 Fri Sep 09 2011 8:44pm
Tail End Charlie
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
16gb USB works fine....just make sure it's correctly formatted
Post #313117 Sat Sep 10 2011 3:02pm
