Home > General > maximum size of USB in MY10 |
Gerico Member Since: 02 Jul 2011 Location: Essex Posts: 224 |
Physical size of the connector should be standard (and actual sticks come in all sorts of shapes and sizes) so I can only assume you mean the actual memory size. In theory this should be limitless.
Fri Sep 09 2011 5:15pm |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 |
Think a lot of cars struggle with anything over 4gb |
Fri Sep 09 2011 5:28pm |
Mines at least 8gb it could be 16gb and fine.
Fri Sep 09 2011 5:59pm |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
yep that's my question.. systems struggle because of the file allocation table size. Would you mind confirming if your 16gb works? I am about to order some new sticks ============
Fri Sep 09 2011 8:44pm |
Tail End Charlie Member Since: 10 Aug 2011 Location: Bristol Posts: 14 |
16gb USB works fine....just make sure it's correctly formatted |
Sat Sep 10 2011 3:02pm |
