Home > Technical > Squeak from wheel & vibration through steering wheel?
BIG DJ
I have an annoying squeak from the front drivers wheel which has gradually got worse. The squeak goes when I touch the brake but comes back again. Also noticed that I get a vibration from the steering wheel. This happens at all speeds but is more noticeable at higher speeds. This also only happens when the wheel is turned slightly either way. If the steering wheel is dead centre I feel no vibration.
Any ideas guys?
Thanks
Adam Thumbs Up
Post #312160 Thu Sep 01 2011 8:33am
BIG DJ
Crying or Very sad
Post #312508 Sun Sep 04 2011 7:07pm
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
Check that the Weights on the wheel have not come off. If they have then you will need re balancing. The squeak might be a stone trapped? Does it feel unsafe to drive? Have you hit any big potholes? The vibrations can be a pain to find. You might need new discs and pads? When were they last changed or have they been? If no joy from this lot then could be a dealer trip. Big Cry Good luck with it.
Post #312509 Sun Sep 04 2011 7:31pm
simon1233
Possibly you have a wheel bearing that is on it's way out? The disappearance of the vibration/noise when you brake is a classic sign of worn bearings.
Jack the car up and see if there is any lateral movement in the wheel (rocking from top to bottom) if there is movement your bearing is knackered. They are sealed for life and have to be replaced, cannot add more grease to see if you get a little longer out of them.
Post #312512 Sun Sep 04 2011 7:48pm
JoeRRS
I had something very similar recently thought it was comming from the front wheels turned out it was the rear diff that needed replacing even the garage thought it was wheel bearing to begin with.
Post #312513 Sun Sep 04 2011 7:51pm
BIG DJ
Not balancing as surely this would happen even when the wheel was straight? Doesn't feel unsafe just annoying. Pads not long been done so shouldn't be that either Thumbs Up
Post #312650 Tue Sep 06 2011 7:56am
BIG DJ
This is what I was thinking of but then again I'm no mechanic Thumbs Up
Post #312651 Tue Sep 06 2011 7:58am
BIG DJ
Even the vibration through the wheel? I would have thought that if it was the diff you wouldn't feel it through the steering wheel?
Post #312652 Tue Sep 06 2011 8:01am
tuneman
Re: Squeak from wheel & vibration through steering wheel
Any ideas guys?
Thanks
Adam Thumbs Up
I have the same problem. Just the squeak on a TDV8. Been a while and have justed booked it in to se if they can resolve it. They did look at it a couple of times and somewaht deglaze or skim the disc I think but it went and returned. Hear it at low speeds and pretty sure it is from the rear right. Goes when I brake as well. Squeak is intermittent.
I suspected the wheel bearing but they said no. Anyhow will leave it with them till it is sorted later this month and will tell them to pay attention to the rear diff as well.
Post #312665 Tue Sep 06 2011 11:05am
