Home > Technical > Grill Removal + SatNav DVD Removal?
kismet110
Hi all
Had my SC grill swapped for a colour-coded Hawke Saker jobbie, needed to change one of the headlight bulbs but after depressing the four clips at the top and pulling on the lugs in the bottom corners it's still sticking bottom middle - is there another clip/lug there?
Don't wanna force it (also not much place to get a good grip on this grill compared to the SC one) so anyone know the 'correct' way of freeing this up? Have given a few midl pulls but not budging Confused
Also mentioned this on another thread (and seen posts from people via Search) but am confused; I thought to get to the SatNav the passenger seat needed to be moved fully forward and up but this shows the back of the unit? However, moving it fully back the underneath of the seat has a black plastic panel in place - how is this removed?
Thanks.
Ali
Post #282821 Sun Dec 12 2010 2:59pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Re: Grill Removal + SatNav DVD Removal?
kismet110 wrote:
Hi all
Thanks.
Ali
When i changed my front grill it was teh clips along the top and a good pull to get them out at the bottom/middle, see here
As for the sat nav i already commented on your other post that you do indeed use the method of fully up & forward, i changed my disc from the rear of the car very simple to do. The sat nav unit has a lock on the disc loader though on the right hand side from the rear of the unit if i remember correctly
Post #282835 Sun Dec 12 2010 4:28pm
kismet110
Thanks Chris, seen that video and tried likewise, still refuses to budge from the bottom middle Sad
The SC Grill has plenty of space between the vents to grab hold of for giving a good hard pull, the Hawke variant is not so accomodating.
Will have another go on the satnav, how much simpler it would be if the DVD slot was facing backwards!
Ali
Post #282849 Sun Dec 12 2010 7:47pm
chris mc
My thoughts exactly on the Sat Nav, as for the grill i would just play safe and contact a stockist.
Post #282869 Mon Dec 13 2010 7:19am
Grip it firmly and tug harder Very Happy RRS gone
Post #282905 Mon Dec 13 2010 2:00pm
chris mc
I have said that a few times lol
Post #282912 Mon Dec 13 2010 3:53pm
matrix13
change my grill, nearly lost my fingers doing so, need to pull hard
Post #311896 Mon Aug 29 2011 9:45pm
vandeheide
Jersey 2009 Range Rover Sport TDV8 HSE Java Black
Sat Nav disc change
Hi Ali
If you ensure that the seat is up and as far forward as possible - then with your left hand feel the sliding mechanism on the front left hand side of the unit. Move it across and then depress the button on the right hand side. The disc will eject - take it out gently using both hands and there you go! When replacing just offer up teh disc and it will reload. Do not forget to slide the mechanism back to lock it.
regards
Paul
Post #312112 Wed Aug 31 2011 7:20pm
