![]() | Home > Technical > Transmission Fault...car wont start |
Dranged1 Member Since: 09 Aug 2011 Location: Miami, fl Posts: 6 ![]() ![]() ![]() |
i have a 2006 rrs....my mother drove it to work and when she was about to leave the car wouldnt start....the error message transmission fault and hdc fault came up.....i went ahead and checked the battery cause i read on the forum that might be the problem....the cca was low on the battery so bought a new one....the hdc fault went away but the car still wont start....any ideas???? |
yepssss its in gear....i tried it in park and neutral....nothing!!!!.......but im getting the "transmission fault" error in the dash......please help me!!!!! |
kieltdv8 Member Since: 22 Dec 2010 Location: perth Posts: 119 ![]() ![]() ![]() |
Deranged1
hey kieltdv8....i could unlock/lock the doors with the remote.....when i put the key in the ignition everything turns on fine...radio lights etc.....when i turn to try and start it, it make one click and thats it...in the cluster it says transmission fault..... |
Sounds like a dead battery. 2005 Zambezi TDV6 - Gone but not forgotten
Join the AA |
AA in the USA is probably more associated with drinking. Seriously there can be enough juice in your battery to open doors, turn radio & lights on but not turn the engine. If you have time try recharging the battery and see what results you get. 2005 Zambezi TDV6 - Gone but not forgotten
Doh !! i didn't realise he was in the usa |
heyyy....when the problem first started i decided to check the battery and it wasnt good...so i changed it hoping that will be the problem...but it wasnt....so the batery is brand new and still no starting.....i tried looking in all the posts for something similar but came up negative.....yeah AA is situated with drinking...i joined AA already after im here having this problem!!!!!...heheh...appreaciate the help fellas |
Any DTCs on the dash? Malaysia Boleh!
Go to the bottom of the class ![]() Audi SQ5...Gone Audi Q7 S-Line 240 3.0TDI Gone Audi A6 Allroad Sport 270 3.0TDI |
DTCs???....whas that? |
Diagnostic Trouble Codes
nope no DTCs....just transmission fault!!!!!.....someone pleaseeeee helllppppp meeeee...thanks |
