Home > General > rrs key/remote and cd
poolie
2006 Range Rover Sport TDV6 HST Java Black
Hi guys finally bought rrs today, got two problems though hope you can help,,
Firstly i only have 1 key and remote isnt working can battery be replaced? Cant seem to get into key.
Secondly cd will not take discs at all, theres none in there, but wont accept cd when trying to slot in. it wont as if its stuck or something.
Thanks in advance poolie.
Post #309341 Wed Aug 10 2011 9:22pm
chrisonite_200
United Kingdom 2005 Range Rover Sport TDV6 HSE Santorini Black
Re: rrs key/remote and cd
I can only comment on the key...there is no battery its rechargeable !! Charges when key is in ignition !! Smile
Post #309347 Wed Aug 10 2011 9:44pm
timcom0
Hi, I had a similar prob when i got mine, i think from the source button press that till you get the cd player showing, then press a disc number i.e. 1 as it has a six disc player when number 1 shows press eject or insert disc, then do the same select number 2 and insert disc and so on.
The 6 discs all go in through the same slot.
Hope this is the prob for you, cheers
Post #309349 Wed Aug 10 2011 9:54pm
poolie
thanks for reply guys Smile Sorted sat nav disc just realised that goes under seat. As for key im getting worried Confused Been outside lock doors via dash switch but drivers is staying open.. Cant lock drivers door Confused
Messed about with key pressing numerous times lol But it did work once only opening but wont now Rolling Eyes
Will try what was said about cds in morning but really worried about locking motor up???
Post #309352 Wed Aug 10 2011 10:13pm
chrisonite_200
Not 100% but if you remove the cover on the door handle you should be able to put the key in the door and lock it manually!! Thumbs Up
Post #309353 Wed Aug 10 2011 10:16pm
poolie
Thanks Thumbs Up Itry that. Think the remote is fooked. Any idea how much anew one will be from dealers? Also can you get it in a day?
Post #309356 Wed Aug 10 2011 10:30pm
chrisonite_200
My car went in 2 days a go and they didnt get a key in time as the spare one stopped working!! I think it all depends on the dealership!!
They need to program it too!!
You could just push the lock in when door is open from inside then close door...that should lock it...but remember if they key doesnt work you will have to remove the door handle cover to get back in!! Thumbs Up
Good luck
Post #309357 Wed Aug 10 2011 10:35pm
timcom0
Hi Chris, the other thing may be if car has been sat on the forecourt for a while to discharge key, then it may take a good while for key to recharge, so if you can leave it on the drive for a few hours with the key in ignition may restore charge? Thumbs Up
Post #309368 Thu Aug 11 2011 5:14am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
i think it throws a message on the dash if the key power is low? ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #309409 Thu Aug 11 2011 9:28am
poolie
Had the car in dealers today (stratstone teeside) theyv'e checked key and said that its fine but still not working the locks Confused
They now reckon its a loose wire problem some were in control unit. They reckon they have to take headlining out to check, 2/3 hours labour £70 a hour.
They said this isnt common but has been a problem on other rrs in past.
What do you think guys?
Post #309472 Thu Aug 11 2011 4:36pm
rrsboy
my only comment would be that Stratstones do not have a very good reputation. ============
Post #309474 Thu Aug 11 2011 4:48pm
If you've just bought the car it's their problem and you shouldn't have to pay for the fix - saying that it is Stratstone's so nothing amazes me from that dealership. 2005 Zambezi TDV6 - Gone but not forgotten
Post #309476 Thu Aug 11 2011 5:56pm
poolie
Car was bought privately.
Just been out to shop now car is saying battery low leave key in ignition Surprised
Its got me puggled only had it a day!!!
Post #309482 Thu Aug 11 2011 6:33pm
poolie
Can anyone tell me were reciever is in car for keyfob?
Post #309485 Thu Aug 11 2011 6:47pm
rrsboy
give it a good charge. It's unlikely to be the receiver. ============
Post #309491 Thu Aug 11 2011 7:22pm
