Home > Maintenance & Modifications > Broken Side Step
landy2010
Broken Side Step
the chrome side strip has come off my side step- does anyone know how to fis this or where to fix it- i live in south bucks
or do i have to buy a brand new one and attach the whole piece?
Post #306786 Wed Jul 20 2011 2:09pm
Seems quite a common occurrence and has been covered on here a few times
i understand you can not get replacements, and new steps are required
unless you can get a set of covers fabricated or something
http://www.rrsport.co.uk/forum/topic17091....+step+trim
http://www.rrsport.co.uk/forum/topic20326....+step+trim
http://www.rrsport.co.uk/forum/topic14428....+step+trim
http://www.rrsport.co.uk/forum/topic13858....+step+trim
Post #306789 Wed Jul 20 2011 2:28pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Land Rover Dealers will repair it by fitting some self tappers to the running board.
Very common and yet nothing done about it as usual lol
Post #306802 Wed Jul 20 2011 3:52pm
landy2010
thanks for this will try and use self tapping screws to reattach it- there not any existing holes on the silver trim so how do i attach that to the black side step anyone got any recommendations- do i need to drill a hole into the aliminum and then use the screw?
Post #306804 Wed Jul 20 2011 3:54pm
landy2010
i have taken the metal things that were on the side step off by drilling them out and now a hole is left for each one- how are the self tapping screws used- do these just screw from the inside of the black trim through into the metal trim tp hold it in place or is there a different way of doing this- can someone tell me how to attach these with some instructions
Post #307562 Thu Jul 28 2011 10:09am
craneboy
You shoudl have drilled the rivert out and knock it through with a punch.
If you have, you're left with a perfet sized hole for no.10 1/2 inch pan head self tapping screws (can find at b&q).
For peace of mind I put lock washers on also.
Job done.
Wish I had taken pictures now for you, but could take one of the new set up?
Cheers,
Andy
Post #307625 Thu Jul 28 2011 4:48pm
landy2010
Job done.
Cheers,
Andy
thanks for the reply- that is what i did and i have the holes after knocking the rivets through- so i willl get the self tapping screws now and screw in from the inside of the black side step- where does the washer go - i assume that will be against the head of the screw (on the inside of the black plastic step?)
Post #308092 Mon Aug 01 2011 1:52pm
