![]() | Home > Maintenance & Modifications > Broken Side Step |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Seems quite a common occurrence and has been covered on here a few times
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
Land Rover Dealers will repair it by fitting some self tappers to the running board.
landy2010 Member Since: 16 Feb 2011 Location: UK Posts: 9 ![]() |
thanks for this will try and use self tapping screws to reattach it- there not any existing holes on the silver trim so how do i attach that to the black side step anyone got any recommendations- do i need to drill a hole into the aliminum and then use the screw? |
i have taken the metal things that were on the side step off by drilling them out and now a hole is left for each one- how are the self tapping screws used- do these just screw from the inside of the black trim through into the metal trim tp hold it in place or is there a different way of doing this- can someone tell me how to attach these with some instructions |
craneboy Member Since: 17 Feb 2011 Location: North Wales Posts: 111 ![]() |
You shoudl have drilled the rivert out and knock it through with a punch.
thanks for the reply- that is what i did and i have the holes after knocking the rivets through- so i willl get the self tapping screws now and screw in from the inside of the black side step- where does the washer go - i assume that will be against the head of the screw (on the inside of the black plastic step?) |
