Home > Technical > super heated rear disc- NOT usual suspects!!! |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
My Audi A6 didn't do that at 125mph... Nor did my A4 Avant at 135mph... |
Wed Jul 27 2011 10:09pm |
andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370 |
Used to be able to get the discs on the D3 glowing on a Minehead run up the Black Cat from Tiverton, the finish on the wheels was basicaly a mix of burnt in pad dust and iron fillings from the discs, commuting with DSC off and TR in sand mode to make the go... Thats half the reason I went for the XF, but that ended up being mega heavy on tyres and brakes, pads @ 15k and tyres in less time. 08 2.7 RRS "S"
Wed Jul 27 2011 11:31pm |
Had exactly same problem on XF, rear pads in 12000 miles, never raplaced rear pads before 35000 on anything else! |
Thu Jul 28 2011 12:42pm |
tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242 |
Update...
Thu Jul 28 2011 8:04pm |
Glad you got it sorted, and thanks for the update |
Thu Jul 28 2011 8:38pm |
Good one ! at least it kept several hundred quid from those we choose to keep in ungainfull employment, I shall hazard a guess that everything was bone dry and rock hard ! 08 2.7 RRS "S"
Thu Jul 28 2011 9:51pm |
Bone dry, but not so rock hard (only a matter of time though had I have left it longer.
Thu Jul 28 2011 10:13pm |
It is possible to disconnect the calliper from the system by gently clamping the hose, I'd need to consult my Oracle on the method for you to use to re bleed, in some instances the ABS can privide the motive power to bleed through, I've achieved = results by pulling fluid through with the pedal pressed down. 08 2.7 RRS "S"
Thu Jul 28 2011 10:36pm |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 |
this is the same as my car at the moment, new caliper to fit and ill post back the results |
Thu Feb 04 2016 5:49pm |
so ive replaced the caliper and everything seems ok and moving freely, the caliper was badly coroded, now im having a mare trying to bleed the brakes, they feel very spongey can anyone advise |
Fri Feb 05 2016 2:00pm |
What method are you using to bleed the brakes - the old-fashioned manual way? The bleed nipples tend to allow air back in via the loose-fitting threads using the manual method of pumping the pedal and opening/closing the bleed nipple.
Fri Feb 05 2016 2:24pm |
ive been doing it the old way and im getting the fluid through ok, im loosing fluid through the blled nipple thread on the new caliper when im bleeding that one, ill get some thread tape on it to see if that will help ill have another go tomorrow.
Fri Feb 05 2016 6:11pm |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 |
Get hold of a decent pressure bleeder. That'll sort it. Or if you're feeling industrious, make one from an old fuel pump and a 5 litre oil can like I did |
Sat Feb 06 2016 8:53pm |
cheers guys ive sussed it with a bit of help from bodsy, ive fitted a nearside caliper to the offside so it will never bleed as the nipple is at the bottom, didnt realise it was the nearside when i took it out the box, so ive a new one coming and ill change them both. |
Sun Feb 07 2016 9:39am |
