![]() | Home > Technical > Cruise control speed V Speedo |
rm0rgan Member Since: 04 Jun 2011 Location: Ross on Wye Posts: 42 ![]() ![]() ![]() |
Anyone? Wife's Car: BLACK RRS TDV8 HSE with all the bits |
the speedo needle should read a littel higher...but the speed can fluxiate and isnt "set" so you can at times be going a little slower or faster (hence the bottom display may say 69 when cruise is set to 70 and the speedo needle could show 70 or 71
Jmac Member Since: 17 Feb 2011 Location: South Posts: 125 ![]() ![]() ![]() |
Mine's the same 75 mph on the digital readout to show 70 mph on the dial. Weird. J |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
Mine is the same, complained about it from day one but the dealer said they could do nothing about it. to get the speedo to read 70km/h I have to set 74km/h on the cruise, for 120km/h I have to set 126km/h on the cruise.
Thanks for the answers - I guess its just a case of TADTS then.
Mine is only a few MPH out which is what it should be
I did wonder this as it has the 20" supercharger wheels on it. Is this something I can check somehow on the car - maybe a menu somewhere? ![]() ![]() My Car: Lotus Exige S2 PP & TP ![]() |
The 255/50 R19" tyres are the same diameter as the 275/40 R20" tyres so there should be no speedometer correction needed.
Ah - I was wondering that as I was writing my last reply/question - thanks for confirming. |
andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370 ![]() ![]() |
I recall the XF had a facility to recalibrate to tyre size, I guess it may dribble over to LR at some point. 08 2.7 RRS "S"
They never match exactly when changing rim size.
on the 80scool (Toyota Landcruiser) forum a few years ago they did a test to see if there was any diffrence between diffrent aspect ratio tyres with the same diameter and how it would affect speedo readings, they also did a test to see if there was a diffrence between full pressure in the tyres and airing them down and they found no diffrence in the speedo reading. They did not test the tyres at high speed tho as they were really only intrested in the results for sand driving and it was a good excuse for a meet and a few tinnies |
interesting, but on same rim diameter you say... which would make sense, the tyre profilel is a % of the tyre width so there is ltd width that can be fitted to the same car before the wall is changed significantly.
I know that my 110 speedo is bang on with my Garmin with it's oversize tyres on it (285/75/16 BFG M/T's) and have seen some horrendous errors on bike speedo's because of course the faster you go the bigger the difference, in one case @ 90mph it was under by 10 mph so we where pleasantly impressed when we found this out because it achieved an indicated 180 so in reality nudged 200 |
