Home > Technical > Cruise control speed V Speedo
rm0rgan
Does anyone else have this problem?
When I set my cruise control at say 70 on the LCD, my speedo never reads the same - actually quite a bit slower.
How do I recalibrate or is this a case of TADTS Question Wife's Car: BLACK RRS TDV8 HSE with all the bits Smile
My Car: Lotus Exige S2 PP & TP Smile)
Post #307149 Sun Jul 24 2011 5:37pm
rm0rgan
Anyone? Wife's Car: BLACK RRS TDV8 HSE with all the bits Smile
Post #307187 Sun Jul 24 2011 9:16pm
mse
the speedo needle should read a littel higher...but the speed can fluxiate and isnt "set" so you can at times be going a little slower or faster (hence the bottom display may say 69 when cruise is set to 70 and the speedo needle could show 70 or 71
All fine - you cant calibrate anyway. Mike
2014 Facelift Discovery
Post #307192 Sun Jul 24 2011 10:06pm
Jmac
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Re: Cruise control speed V Speedo
Mine's the same 75 mph on the digital readout to show 70 mph on the dial. Weird.
J
Post #307198 Mon Jul 25 2011 6:22am
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Mine is the same, complained about it from day one but the dealer said they could do nothing about it. to get the speedo to read 70km/h I have to set 74km/h on the cruise, for 120km/h I have to set 126km/h on the cruise.
Also on a related topic with the original wheels/tyres when the speedo reads 70 km/h the GPS reads 68km/h which compared with other cars I have driven is fairly accurate, with my 19" wheels with the 255/55 MT/R tyres 70km/h on the speedo gives 71km/h on the GPS
On my MG I can enter the service menu on the instrument cluster and re-calibrate the speedo if I really wished, there is a list of offsets for both the speedo and for the inertial navigation counting the pulses from the ABS sensor to send to the sat nav. Sons of dogs come hither and get flesh
Clan Cameron
Post #307204 Mon Jul 25 2011 9:34am
rm0rgan
Thanks for the answers - I guess its just a case of TADTS then.
Its slightly annoying though as I used to set the Cruise at 30 to ensure I stuck to the speed limit in town, but to be doing an indicated 25/26 when the cruise is set to 30 makes me feel im holding up the traffic!
Still, better to be going below 30 than over it Smile Wife's Car: BLACK RRS TDV8 HSE with all the bits Smile
Post #307208 Mon Jul 25 2011 9:47am
mse
Mine is only a few MPH out which is what it should be
I wonder if the dealers havent set your tyre size setting properly as it should been massively different Mike
Post #307315 Mon Jul 25 2011 6:17pm
rm0rgan
I did wonder this as it has the 20" supercharger wheels on it. Is this something I can check somehow on the car - maybe a menu somewhere?
Thumbs Up Wife's Car: BLACK RRS TDV8 HSE with all the bits Smile
Post #307316 Mon Jul 25 2011 6:35pm
Alicatt
The 255/50 R19" tyres are the same diameter as the 275/40 R20" tyres so there should be no speedometer correction needed.
I have 255/55 R19" tyres for off road use and they are a little taller in diameter so I have to take that into account when reading the speedometer. Sons of dogs come hither and get flesh
Clan Cameron
Post #307342 Tue Jul 26 2011 7:20am
rm0rgan
Ah - I was wondering that as I was writing my last reply/question - thanks for confirming. Thumbs Up Wife's Car: BLACK RRS TDV8 HSE with all the bits Smile
Post #307344 Tue Jul 26 2011 7:34am
andy r
2008 Range Rover Sport TDV6 S Zambezi Silver
I recall the XF had a facility to recalibrate to tyre size, I guess it may dribble over to LR at some point. 08 2.7 RRS "S"
Td5 110......very modified
RS 5
Kawasaki ZX12R Censored me, it's quick !
Post #307351 Tue Jul 26 2011 8:36am
They never match exactly when changing rim size.
The 20's read slightly faster, the 22's slower
If not, why do LR tell the gearbox module what alloy size is on the car if it doesn't effect the rolling circum slightly. Whistle
With my 22's the speedo is 1mph SLOW and the cruise control is 3mph FAST RRS gone
Post #307354 Tue Jul 26 2011 8:56am
Alicatt
on the 80scool (Toyota Landcruiser) forum a few years ago they did a test to see if there was any diffrence between diffrent aspect ratio tyres with the same diameter and how it would affect speedo readings, they also did a test to see if there was a diffrence between full pressure in the tyres and airing them down and they found no diffrence in the speedo reading. They did not test the tyres at high speed tho as they were really only intrested in the results for sand driving and it was a good excuse for a meet and a few tinnies Whistle Sons of dogs come hither and get flesh
Clan Cameron
Post #307356 Tue Jul 26 2011 9:08am
interesting, but on same rim diameter you say... which would make sense, the tyre profilel is a % of the tyre width so there is ltd width that can be fitted to the same car before the wall is changed significantly.
With a 19" alloy and a 22" alloy the profile changes by 2.77cm, that's a big flex difference between a 35 profile and a 55 profile and also results in a rolling radius difference of 6cm RRS gone
Post #307357 Tue Jul 26 2011 9:19am
andy r
I know that my 110 speedo is bang on with my Garmin with it's oversize tyres on it (285/75/16 BFG M/T's) and have seen some horrendous errors on bike speedo's because of course the faster you go the bigger the difference, in one case @ 90mph it was under by 10 mph so we where pleasantly impressed when we found this out because it achieved an indicated 180 so in reality nudged 200 Shocked I think manufacturers ought to be able to design a system that is GPS linked and updates the speedo on a regular basis. 08 2.7 RRS "S"
RS 5
Post #307358 Tue Jul 26 2011 9:29am
