Home > Technical > Accuracy of speedo |
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 |
It will never give you a true reading unless you have it calibrated also what size tyres do you have it on ? WHen I borrowed Ady555 road angel it was 2mph out on mine. |
Sat Jul 23 2011 3:16pm |
by law your speedo cannot under read eg when you are doing 30 actual it cannot tell you your indicated speed is 29.9.
Sat Jul 23 2011 6:37pm |
My road angel vantage is spot on with a few roadside digital speed checks, also a police roadside radar gun and is spot on with my speedo with 285/35/22" wheels and tyre combo, so i'm very confident my speed is correct |
Sat Jul 23 2011 7:32pm |
I would be very surprise at that none of our 4 current cars, 4 GPS's are - nor to my portable aviation GPS - which is more accurate than all of the prior. What you might fine is you 22" wheels have removed some of the inbuilt error, so your actual speed is now similar to your indicated speed...which is you think sensibly isnt the thing you want; as your margin for error is decreased. Mike 2014 Facelift Discovery |
Sat Jul 23 2011 8:26pm |
Yes you are probably right, i only ever use my road angel as my speedo which is easier to see where ive positioned it on my dash |
Sun Jul 24 2011 11:34am |
