Home > Technical > DVD troubles |
Good to hear - maybe you should feed this back to your service dept, with an invoice for your time
Mon Dec 24 2007 8:25am |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Nice one Umbertob RRS TDV6 Gone but still around
Mon Dec 24 2007 8:59am |
gseum Member Since: 15 Feb 2010 Location: Germany Posts: 32 |
Hi, I have a LR4 modell 2010 from the US, but navigation harddisk was changed to european version. The DVD changer for RSE also shows "Video signal system is not correct" with a PAL DVD inside. Unfortunately your solution does not work - i tried on/off for several seconds with different switch settings (left or right monitor). I think the DVD changer is set to NTSC and the head unit to pal? Any solutions to change the changer to PAL? Thanks for your advice gseum |
Tue Jul 19 2011 9:24pm |
If its the facelift disco then you can change the pal/NTSC from an option in the front unit. Have you looked in your manual? Also remember a 2010 vehicle is under warranty Mike 2014 Facelift Discovery |
Tue Jul 19 2011 10:36pm |
Hello,
Tue Jul 19 2011 10:46pm |
Did you have the entire unit changed, or just the maps downloaded?
Wed Jul 20 2011 6:31am |
Wed Jul 20 2011 7:00am |
Sounds like you have identified you own fault, as it should work tried mine this morning Mike
Wed Jul 20 2011 1:11pm |
... but the screen format SHOULD be changeable from NTSC to PAL, but is not working. So I think, something is wrong... Discovery 4/LR4 5.0l V8 HSE from US
Wed Jul 20 2011 1:38pm |
my point is - it is, so thats your fault to get fixed Mike
Wed Jul 20 2011 8:33pm |
ujensen Member Since: 18 Dec 2017 Location: SAO PAULO Posts: 1 |
Anyone found a solution for the "video signal system is not correct" issue ? I had this once before and pressing the on/off in rear seat remote control solved the issue. Now it happened again, after a dead battery, but the procedure is not working anymore. Any idea what i could try to solve it ? |
Mon Dec 18 2017 1:30pm |
Joebrain1989 Member Since: 09 Jan 2021 Location: Filey Posts: 1 |
Did this issue ever get solved? I have exactly the same issue but want to see if it has been solved before I buy a new dvd changer. Thanks |
Sat Jan 09 2021 11:52am |
