![]() | Home > Technical > DVD troubles |
Good to hear - maybe you should feed this back to your service dept, with an invoice for your time |
Nice one Umbertob |
gseum Member Since: 15 Feb 2010 Location: Germany Posts: 32 ![]() ![]() ![]() |
Hi, I have a LR4 modell 2010 from the US, but navigation harddisk was changed to european version. The DVD changer for RSE also shows "Video signal system is not correct" with a PAL DVD inside. Unfortunately your solution does not work - i tried on/off for several seconds with different switch settings (left or right monitor). I think the DVD changer is set to NTSC and the head unit to pal? Any solutions to change the changer to PAL? Thanks for your advice gseum |
If its the facelift disco then you can change the pal/NTSC from an option in the front unit. Have you looked in your manual? Also remember a 2010 vehicle is under warranty Mike 2014 Facelift Discovery |
Hello,
Did you have the entire unit changed, or just the maps downloaded?
Sounds like you have identified you own fault, as it should work tried mine this morning Mike
... but the screen format SHOULD be changeable from NTSC to PAL, but is not working. So I think, something is wrong... Discovery 4/LR4 5.0l V8 HSE from US
my point is - it is, so thats your fault to get fixed Mike
ujensen Member Since: 18 Dec 2017 Location: SAO PAULO Posts: 1 ![]() ![]() |
Anyone found a solution for the "video signal system is not correct" issue ? I had this once before and pressing the on/off in rear seat remote control solved the issue. Now it happened again, after a dead battery, but the procedure is not working anymore. Any idea what i could try to solve it ? |
Joebrain1989 Member Since: 09 Jan 2021 Location: Filey Posts: 1 ![]() ![]() |
Did this issue ever get solved? I have exactly the same issue but want to see if it has been solved before I buy a new dvd changer. Thanks |
