Home > Maintenance & Modifications > Cleaning alloys |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
Wolf chemicals deironizer (brake duster) then a sealant
Wed Jul 13 2011 10:16pm |
RRS Craig Member Since: 14 Jun 2011 Location: Britain Posts: 139 |
As the wheels are brand new I'm
Wed Jul 13 2011 10:36pm |
No the brand is wolf chemicals
Wed Jul 13 2011 10:43pm |
Cheers pinks if I wanted to get the sealant you stated and a separate shampoo which would you suggest? Also do they do a cleaner for the dash, not dash board because it's leather. Cheers mate been really helpful looks good stuff! RRS |
Thu Jul 14 2011 6:33am |
I use the autoglym sealant and occasionally wheel cleaner - been on since new and takes 30seconds to clean.
Thu Jul 14 2011 8:08am |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
+1 for the Autoglym aerosol spray. Cheap as chips and pretty good stuff. Doesn't last like the liquid sealants buts its a doddle to redo. FF 4.4 V8 Soooo looking forward to this bad boy
Thu Jul 14 2011 9:34am |
If you go for the nano sealent listed, I believe, (i'm sure Polished Bliss could offer advice) if you wanted a cleaner for the wheels then the other link to the cleaner/sealent would be your best option I used to rate Billberrys no acidic wheel cleaner, great for sealed wheels but not so good on burnt on dust For all my plastic dash (lots on the FL2 as you'll know) I use 303 Aerospace protectorant http://www.polishedbliss.co.uk/acatalog/30...ctant.html Great product as i can use on the dash, exterior plastic like mudflaps and engine bay plastic too, best thing is it doesn't leave it all shiny, its left clean and matt/satin finish. Says also can be used on leather too so it might protect the leather dash also (best check with PB on that) Every so often if I need to actually clean the dash, i will use a weak solution of APC (Meguiers All Purpose Cleaner) |
Thu Jul 14 2011 9:36am |
use detailing brushes to get in the gaps, like these, but cheaper http://www.polishedbliss.co.uk/acatalog/sw...-cat4.html |
Thu Jul 14 2011 9:38am |
THanks, Your right - been meaning to order one but always seem to remember when im cleaning it If i bothered i can get the brushes at trade if i place the order when i order other stuff. Mike 2014 Facelift Discovery |
Thu Jul 14 2011 9:41am |
i have used a paint brush in the past, just make sure you tape up any metal with some masking tape first of you'll accidental scratch the alloy if you hit it |
Thu Jul 14 2011 9:45am |
i wont ask how you know!! Mike 2014 Facelift Discovery |
Thu Jul 14 2011 10:14am |
gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542 |
Bilberry, dilute to 50:50 and spray on, works a treat and doesn't have anything harmful in it! |
andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370 |
Best regular treatment I've found is that spray dodgy dealers use to make everything new & shiny, it stays soft & oily and normally comes of with a soapy brush, carefully spray it on, avoiding the discs and move around with a soft brush or cloth |
Thu Jul 14 2011 10:53am |
that will be acid then |
Thu Jul 14 2011 12:43pm |
