Home > Technical > Suspension question
discohead
United Kingdom 2007 Range Rover Sport TDV8 HSE Rimini Red
Suspension question
I've noticed on my tdv8 that when raising the ride height the back of the vehicle seems to go up a lot quicker than the front. Is this a potential problem?
Thanks
Peter I'm back with Land Rover
Post #305415 Thu Jul 07 2011 7:46pm
barry15555
England 2006 Range Rover Sport Supercharged Bonatti Grey
Mines the same, no problem. Thumbs Up Thumbs Up 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels.
Post #305422 Thu Jul 07 2011 8:26pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Is that not because the front has a big lump under the bonnet Smile
Post #305436 Thu Jul 07 2011 9:30pm
NickM
It's normal....
Post #305438 Thu Jul 07 2011 9:32pm
discohead
Thanks. Got a little worried as the disco 3 I had definitely went up and down pretty flat. I'm back with Land Rover
Post #305443 Thu Jul 07 2011 10:36pm
andy r
2008 Range Rover Sport TDV6 S Zambezi Silver
The RRS seems to have a totally different characteristic to the D3 when changing the susp height, like you say the D3 just sort of goes up whereas the Sport sort of gathers it's thoughts then sends air to each corner willy nilly.
Post #305485 Fri Jul 08 2011 9:01am
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
Andy that will be the 17 stone effect Whistle Smile
Post #305487 Fri Jul 08 2011 9:02am
mrfixit
I wouldn't have thought your that heavy Foxy Rolling with laughter
Post #305490 Fri Jul 08 2011 9:10am
Siberianfox
Nope but ANdy is ....http://www.rrsport.co.uk/forum/topic22997.html?highlight=
My suspension is ok, Its the same motions as the FFRR so I havent noticed any different. Only had a D4 on as a courtesy car so didnt try the suspensions. Smile
Post #305493 Fri Jul 08 2011 9:15am
discohead
So the conclusion is that I need to go on a diet.......
Big Cry I'm back with Land Rover
Post #305600 Fri Jul 08 2011 9:30pm
Siberianfox
Whistle No comment... But I doubt it. How old is your car? If it's still under M W I'd just book it in to dealer. Smile
Post #305604 Fri Jul 08 2011 9:39pm
discohead
Car is outside MW so I think I'll just get it checked at the next service unless it gets worse. I'm back with Land Rover
Post #305612 Fri Jul 08 2011 9:48pm
Siberianfox
Please tell me you have a warranty on your car disco head . Smile
Post #305613 Fri Jul 08 2011 9:49pm
discohead
No, actually never been s fan of them. Cost of repairs versus warranty. They are good for peace of mind but at the end of the day it has to work out more expensive otherwise the warranty companies wouldn't make any money. Instead I use independent specialists. They are often ex LR and tend to know a hell of a lot more than most of the main dealer monkeys.
Only time I did was when I had a maserati. Now if, no when, they go wrong you are in a world of hurt. Took it in for a slight noise from the gearbox, cost nearly £3,000. I'm back with Land Rover
Post #305617 Fri Jul 08 2011 10:01pm
