![]() | Home > General > latest Mod |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
You take one of the plugs out of the sat nav plug it into the gvif and plug the gvif plug into the socket you freed up on the sat nav |
jamiequ1 Member Since: 23 Jan 2011 Location: london Posts: 58 ![]() |
Doyou have to run a leaf up to the nav ? I thought you just plugged it into the box under the seat ? |
No lead to the tv as the sat nav already goes there,your just adding in the loop so to speak,its literally a 10 second job plug and play |
Cheers fixit, I think I'm going to order it , one thing , once you pass the camara cable into the hole above the tailgate how do you thread it to the b post , do you take the headlining down? |
Please call me Steve |
Cheers Steve |
felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203 ![]() ![]() ![]() |
just see this on fleebay. not sure if it would do the same as above but bloody cheap!!
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 ![]() ![]() ![]() |
Looks like the same one that comes with the kit!
It would put a pic on the screen if you wired it via an smb-rca lead but you would have to select it manually via 753 hack everytime so not very practical |
Guys , what sort of instructions does that kit come with ? |
Were really to good to you |
You really are,top man |
Happy to help if I can |
Just looking at that Steve , do i have to put power to it or does it get it from the box once plug into it? |
