![]() | Home > General > Bi-Xenon headlight switching for Europe. |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
I just pay my friendly dealer to do it,£50 both ways. |
Yes Chris you might be right; although as it is all held in by clips it should be easy enough - but not mid-trip.
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
Easy job, takes ten mins max , do it while in queue for ferry, the grill pops out if you give it a yank, then thread a piece of ribbon under the leaver to undo the lights, again pull upwards, it is tight so you can't get the leverage if you use your hands, then switch the leaver on the back of the light.
Thanks Dave
I was told you had to take the whole unit out,on the basis that knowing my luck I would probably drop at least 1 I thought £50 to do it twice was a bargain. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Portman Len Member Since: 09 May 2011 Location: Suffolk Posts: 57 ![]() ![]() ![]() |
I have the auto dimming headlights on my 2011 MY, and I noticed that in the setup on the steering wheel I can change the side from left to right depending upon what country I'm driving in.
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 ![]() ![]() ![]() |
You are all mad... I have taken the RRS & The FFRR over to France loads and never have i dipped or messed with the lights. All the French care about is that you have a warning triangle and a reflective jacket and spare bulbs.
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
it is easy to switch over, but I do keep a set of UK headlights to put in the car in for when I'm in the UK. Got them from Tim when he bought the FFRR.
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
It is very easy to do, as codfather explains above. I have done it twice, but then indeed there is the autodimming function which does exactly that. Vadim A. |
Foxy - You might be right I could be "mad".
Solution for anyone interested. Don't have any power turned on as Xenon's use high voltage.
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
i would like to know the answer to this too! does changing the setting just affect the auto-dimming feature, or does it adjust the actual lights too? i suspect the former, but how cool would the latter be! ============ 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
Not a problem for Euopean LHD RR Sports as the head lamps only dip straight down, unlike the UK when they dip down AND to the left. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
Are thought mine were right. Its LHD. SVR 2018 in Santorini Black. |
