Home > Technical > TV Reception
mse
TV Reception
How good do you guys find the TV Reception in the sport.
Sometimes its good, but more often than not its not great and i wonder if there is something wrong the dealer needs to look at.
Appreciate there is probably a host of factors that could affect it - but on the whole how do you guys find the quality and channel choice? Mike
2014 Facelift Discovery
Post #303834 Fri Jun 24 2011 8:16am
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
I have no issues with my TV. I have tried it up and down the country and it seems to be really good. Better than the Tv in the FFRR anyhow.
Sorry cant be much help.
I do have one issue with it but not a reception one. Why is it that you can get adult babes on it and when you put the tv on its always the first channel !!! Smile
Post #303835 Fri Jun 24 2011 8:18am
might get better when the digital switch over is fully done as they be boosting the signal
Post #303839 Fri Jun 24 2011 8:39am
Jonny Fresh
I find it good everywhere
Post #303841 Fri Jun 24 2011 8:55am
gilford
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
I had digital TV in my M5 and my M3 and could not get reception anywhere up my end, which is why I went for the PS3 install this time round Very Happy
Post #303842 Fri Jun 24 2011 9:01am
mse
Thanks Guys
Its leading me to wonder if there is something up with it - or we are just not is a great area yet.
Do you get all the digital channels or only a selection?
I dont always get all the channels - like i dont always get BBC1!
Blast - the first niggle with the sport! Mike
Post #303844 Fri Jun 24 2011 9:16am
Siberianfox
I seem to get all the channels. Some I dont want and wish i could take off tbh!!! Smile
Post #303846 Fri Jun 24 2011 9:22am
scarey
unless you are in a medium/strong transmission area then you will have reception problems, even then if you are travelling the signal will drop in and out...most houses have to have an ariel on the roof to get a decent picture...
Post #303848 Fri Jun 24 2011 10:20am
Siberianfox
The RRS does have 18 individual ariels, all which aid the TV.
Is your tv an aftermarket product? Smile
Post #303849 Fri Jun 24 2011 10:22am
mse
No 2011 MY so its the genuine deal!
Just been out ive got 12 - a different few to where i usually watch it whilst waiting for a meeting i have to be early to in order to park!
No BBC channels here - but BBC there - certainly not all the digital channels.
I know there are 2 aerials each side, one on the roof and one at the front - i cant figure why its getting some not all the stations.
Quality wise - of the 12 it acquired - they are flawless
I cant see a way to test the aerials or signal - i looked in the secret menu...any ideas? There are a few logged faults for the entertainment unit! Mike
Post #303851 Fri Jun 24 2011 10:31am
scarey
strange..
digital freeview broadcasts in multiplexes and the BBCA multiplexe has BBC1,2,3,4,news,parliment and 301 on it..if you dont receive any of these channels then either your not picking this multiplexe up [drive a distance to see] or there is a fault in your unit.
edit.......it could also be that your area hasn't switched fully to digital, if you receive from the sutton coldfield transmitter then this wont go fully digital till september... ..if that's the case you should get a decent analogue signal but not a good digital one...
Post #303852 Fri Jun 24 2011 10:45am
mse
I think we are going fully in September - so maybe that has a factor. When it gets some BBC channels digitally (News and Parliment usually) it doesnt get them all
Am i missing how you switch it to analogue - i have only been getting digital channels on the TV unit
Maybe a drive is in order! Mike
Post #303853 Fri Jun 24 2011 11:16am
scarey
not sure whether you have a hybrid tuner or not, i suspect that you do...setting will be in the menu somewhere...
Post #303855 Fri Jun 24 2011 11:30am
mse
I would have thought it does as standard - ill have another look later, thanks. Its definately doing digital the only setting ive found is UK and what PAL to choose. Mike
Post #303857 Fri Jun 24 2011 11:39am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Not anywhere near Rugby are you Question
Post #303925 Fri Jun 24 2011 10:53pm
