![]() | Home > General > Cleaning....Need upto date advice . |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Just get a Megs quick clay kit, comes with clay and the detailer spray as a lube, if you have any detailer spray left you can keep it and use it for quick wipe overs
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 ![]() ![]() ![]() |
Cheers nick just bought the maguires smooth surface clay kit
JasV6HSE Member Since: 06 Aug 2010 Location: Notts Posts: 56 ![]() ![]() ![]() |
This is what i do to get a fantastic finish....
Wash, rinse & then clay, then quick wash once again
0cj0 Member Since: 23 Sep 2010 Location: York Posts: 290 ![]() ![]() |
Does it really need claying Foxy? 2011 car?
Youll be amazed how much stuff can come off in a short time on the road, if your giving it a good polish its worth it in my opinion |
jaxx Member Since: 13 Jun 2011 Location: Pyrenees Posts: 62 ![]() ![]() ![]() |
JasV6HSE has got it right, plenty of lube for the clay bar and light strokes etc twice a year should be good and yes it will make a big difference etc. watch the water dissapear when you rinse after the next wash. run your finger over the car before you clay and you will feel all the contaminants etc. then agian after clay it should be super smooth like polished glass.
Claying has always seemed pointless to me Mike
NickM Member Since: 14 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
Claying is the single most important part of cleaning a car. Can't stress that enough |
the polish cloth will simply slide off a clayed car |
gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542 ![]() ![]() ![]() |
If you don't clay the car then you are just rubbing contaminants into the paintwork and creating swirls!
I am knackered !!! 4 and a half hours and its clean
Excellent work......looks amazing. Just use a rapid Detailer to top it up each day and you may never have to wash it for a week!! Or if it needs it, just rinse it off with a hose and dry it off....... |
Thanks Nick and thanks for your advice. Ha ha I bet you thought I was crazy ringing you up and asking how the hell I used the clay. But once you get used to it, it does seem quite easy.
