Home > Technical > How do you tell if lights are on in auto lights mode? |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 |
The standard green colour light (the same as when you put the lights on manually) lights up on the dashboard everytime lights are activated automatically. Vadim A. |
Mon Jun 06 2011 11:39am |
The RRS auto lights are one of the last ones on the road to light up, look for reflections on the car infront of you that usually lets you know if they are on or not |
Mon Jun 06 2011 12:09pm |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
And in my case the last ones to turn off when exiting a tunnel into bright sunshine. FF 4.4 V8 Soooo looking forward to this bad boy
Mon Jun 06 2011 12:22pm |
Stephen Member Since: 15 Jun 2010 Location: West Sussex Posts: 30 |
I will have to check when i get home as I am sure that no green light comes on when the lights are actually on. In the right light I can see that the dials light up but mostly its quite difficult to tell if they have or not.
Mon Jun 06 2011 1:38pm |
There is a little dial just below the light switch, have you tried adjusting that? It allows you to brighten or dim the instrument lights |
Mon Jun 06 2011 1:43pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
You can also see where you are going, especially at night In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Jun 06 2011 3:04pm |
thats overrated Mike 2014 Facelift Discovery |
Mon Jun 06 2011 5:54pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
The light indicator light didn't come in until MY09 / 58 ish IIRC - As your icon suggests you are in an '55 model i think the only way to know is a dimming of the cluster lights when auto on - flick between auto on and off to note difference (very slight). This is why the indicator light was intro'd |
Mon Jun 06 2011 8:10pm |
green dash light appeared in 2007
Tue Jun 07 2011 9:24am |
Thank you for the replies. I am indeed in a 55 model but thought I was going mad as I could see no indication that lights were on ....because there was no indication. Agree though that is somewhat easier to tell in the dark! |
Tue Jun 07 2011 11:10am |
