Home > Technical > Passenger side front door latch |
marksgd Member Since: 10 Oct 2010 Location: Worcestershire Posts: 68 |
Has any one got any info on changing the passenger door latch. Not quite sure how to take the inside door cover of
Mon May 30 2011 2:04pm |
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 |
This one is for the rear. Hope it helps
Mon May 30 2011 2:37pm |
Thanks very much Pat i think after looking at those photos ill get a mechanic to do it. Ill f**k it up proberbly. |
Mon May 30 2011 3:49pm |
Not sure what exactly the problem you have is. I had the link to hand as my rear passneger door would only open intermittently and I guessed it was the motor. Rather than a trip to the dealer changing the key fob from only open drivers door on first click to open all doors made the problem go away and door opens every time. if your problem is similar may be worth a go? 2011 Autobiography Santorini Black |
Tue May 31 2011 7:34am |
cheers illl try it |
Tue May 31 2011 10:18am |
