Home > Technical > Car wouldn't start ??
X6OOG
England 2007 Range Rover Sport TDV6 HSE Java Black
Hi all, Ive recently (10 days ago) bought a RRS 2.7 HSE 2007, on Sunday she started up fine, I travalled no more than 4 miles and turned her off. 1 hour later she wouldnt start, the lights came on the dash but there wasnt enough umph to turn her over. I eventually got a jump start off a friend and she fired first time. I've taken her back to the garage I bought her from to be checked over. I checked the battery that was fine but the alternator was only putting out 12.7 volts @ idle. Has anyone got any ideas?? as I'm absolutely upset, gutted and angry. Cheers.
Post #301292 Tue May 31 2011 12:00am
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Re: Car wouldn't start ??
Hi there and welcome!
No need to be worried, but your disappointment is totally understandable. SiberianFox just had a similar problem, I'm sure she'll come along and share her info with you. As far as I know some people report a similar problem sometimes, and it always gets fixed in the end. So do not worry!!! Vadim A.
Post #301293 Tue May 31 2011 2:21am
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
Hey There and welcome to the forum !!!
I have indeed have a problem like this but it turns out that it was a faulty connection on the battery. Apparently quite a few of the new models and lots of older models have problems with the battery connections not being on properly.
Hope you get it sorted. However I would make sure that you have a warranty on the car. You can get these aftermarket if it already hasn't come with one. I wouldn't dare run the car without that as a backup.
So welcome to the forum and feel free to post some pictures of your new purchase! Smile
Post #301325 Tue May 31 2011 11:09am
Simply get the garage to fix. 2005 Zambezi TDV6 - Gone but not forgotten
Post #301329 Tue May 31 2011 11:40am
shepp
Welcome x600g
12.7 volts is low, should be around 13.8. Firstly check the battery connections, loosen, use force to push them fully down then tighten. Also when checking the battery voltage, ensure you slightly rev above 2000 rpm. You should have 13.8 then allow to idle, the voltage should still be the same.
Hope this helps
Post #301348 Tue May 31 2011 1:56pm
X6OOG
Thanks guys and gals for your help, I'll keep you up to date with the outcome.
Post #301368 Tue May 31 2011 3:44pm
X6OOG
Hello, sorry for the delay with the solution to my problem but a last minute holiday came first Very Happy Wink The garage I bought it from ran some tests but got some weird results. One minute the battery was fine then it was goosed!!, They decided to let a battery and alternator specialist have a look and it turns out that the battery had got a cell breaking down intermittently.. So a new battery is on and fingers crossed she's started every time.
Post #304005 Sun Jun 26 2011 12:10am
Siberianfox
Hope you had a great holiday and glad you got it sorted in the end !! Thumbs Up Smile
Post #304022 Sun Jun 26 2011 10:06am
