Home > General > side steps
soody
2008 Range Rover Sport TDV8 HSE Java Black
side steps
Some b*******s have nicked the metal trim on my side steps on both sidesof my v8 sport. Could someone please tell me if i can buy a pair of trims separately, or will i have to buy a new set of side steps. They are genuine landrover sides steps. I have looked online and on ebay, some sellers are selling non oem side steps that look exactly the same as the originals, has anyone ever used these, or should i just stick to genuine landrover parts. I would really appreciate it, if someone could help me. Thanks.
Post #300895 Thu May 26 2011 9:31pm
stormer2009
United Kingdom 2009 Range Rover Sport TDV8 HST Santorini Black
just fitted oem on mine very easy to do and look the same as lq land rover
Post #300897 Thu May 26 2011 9:46pm
SilverspeedRRS
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Sumatra Black
Can you fit them without raising the car ?
Post #300952 Fri May 27 2011 12:21pm
Linko
I fitted some non-OEM side steps a couple of months ago. They look the no different to the OEM ones as far as I can tell.
I put the car in off road height and was able to fit them easily enough.
Cheers,
Mark
Post #300965 Fri May 27 2011 1:05pm
FF1078
I fitted Britpart side steps on mine and you cannot tell the difference.
I know Britpart is also known as s Censored part but believe me these are good! I had the use or a ramp when I fitted mine but it could have been done on the ground, they even came with pre-cut sill mouldings to replace the originals.
Post #300989 Fri May 27 2011 4:12pm
