Home > Maintenance & Modifications > Oh yes its knocking ! But we don't know how to fix it ! |
rockhoppers1964 Member Since: 26 Apr 2011 Location: Dunfermline Posts: 39 |
Just had the car in to see about the knocking noise from the front suspension, the dealer was less than impressed with people that trawl the web for information and present it to them when they arrive at the service desk.
Wed May 25 2011 1:10pm |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
This was the story i was told, but mine was in warranty so three trips to the stealers later it was sorted. FF 4.4 V8 Soooo looking forward to this bad boy
Wed May 25 2011 1:55pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
My understanding is that Under Scottish Law you have 5 years protection (7 in England) against design faults with products. This is VERY MUCH a design fault with the RRS. I would try that line with the dealer and if it gets you nowhere then have a wee word with Trading Standards! Of course, if the car has a very high mileage then this may be more difficult to argue. LR standard warranty is 3 years or 60k miles, therefore assumes 20k per year. If your cars current mileage adds up to less than 20k per year then I would argue that it falls under the consumer protection law's defenition. One other point though, I think this only apples if you bought the goods from new. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Wed May 25 2011 4:00pm |
Car only has 43,000 miles on the clock, even though it is an 07 plate, and with full service history.
Thu May 26 2011 12:12pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
Have you had your ARB brackets/bushes packed out? |
Thu May 26 2011 12:42pm |
No, that is to be done too !
Thu May 26 2011 12:58pm |
while i was there they were talking about a 3.6 HSE they bought in on a flat bed truck, 6 months old, suspension failed. Saw the dockets on the desk for it also.
Thu May 26 2011 1:15pm |
Thanks, That is very interesting, i may give that a go as a temporary measure to see if that makes the difference first.
Thu May 26 2011 1:55pm |
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 |
Hi
Thu May 26 2011 2:11pm |
Exactly my feelings,packing them out is easy,you just need to undo them a little and slip a C washer up behind the bracket,3 seperate garages all said my ARB bushes where fine but couldn't find the knock,I'm 99.9% sure that is the issue,not a bad design just over engineered.I've since removed the Arb arm and ground a flat on the collar to prevent it happening in the future I replaced the bushes aswell at the same time seeing as they where off,but they weren't needed really. I think that is why poly bushes seem to give some success as they are a harder compound so dont suffer from compression the same. |
Thu May 26 2011 2:13pm |
Thanks Jim, just found that also, very interesting indeed. Beats a £400 bill, more so when the techs are not sure it will even work ! Andrew Andrew ----------------------- RRS HSE Lux 2011, Black and all the toys. RRS HSE 07 TDV6, Black, Privicy Glass, Sunroof, DVD, light guards, side steps - Gone Freelanders TD4 - Gone Discovery TD3 - Gone Army Lightweight - 2.5 - Gone but not forgotten Range Rover Classic - Gone 110 County - Gone 90 Safari - Gone Series 2A - Gone |
Thu May 26 2011 2:18pm |
The only thing with those is its more rubber to give up after a few months/years.By using a C washer its more of a permanent fix or better still put a flat on the collar for a once and for all fix,because if it starts to knock from this point again the bushes will defo.need replacing as I have 8mm of clearance now. Ps dont worry about undoing the ARB arm completely it is not under compression. |
Thu May 26 2011 2:36pm |
