Home > General > Loose tow hitch
gothatway
United Kingdom 2006 Range Rover Sport TDV6 SE Buckingham Blue
Loose tow hitch
I leave my tow hitch permanently attached as I use it a lot. It has however become somewhat loose in that it will move up and down by maybe 1 cm. This makes for horrible towing, particularly at low speeds and over normal roads. I would expect a part such as this to last the lifetime of the car - but I don't yet know whether it's the hitch itself or the frame it fits into which has worn (or both). Has anyone else come across this problem ? I don't want to fork out £420 to LR (or even £200 + on Ebay) only to find that it's the frame that's the problem.
Post #300184 Sat May 21 2011 5:03pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
I presume you are talking about the removable one??, best seeing if you can borrow one to see if it is the bar, go to the dealer if you have to, I am sure they would have a spare one knocking about. If it is the female coupling on the chassis that has worn, I doubt that could be fixed other than getting a blacksmith to weld in a plate to make the hole smaller?
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #300208 Sat May 21 2011 10:06pm
DrLex
Iceland
As the codfather writes, best get it checked out- read this thread on the sister site for an RRS incident & mention of play in the fitment.
Post #300220 Sun May 22 2011 7:51am
