![]() | Home > General > Loose tow hitch |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
I presume you are talking about the removable one??, best seeing if you can borrow one to see if it is the bar, go to the dealer if you have to, I am sure they would have a spare one knocking about. If it is the female coupling on the chassis that has worn, I doubt that could be fixed other than getting a blacksmith to weld in a plate to make the hole smaller?
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 ![]() ![]() |
As the codfather writes, best get it checked out- read this thread on the sister site for an RRS incident & mention of play in the fitment. |
