Home > Technical > Brake Pad Warning Light |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 |
Sounds like a wiring fault, maybe check all the connections under the wheel arches for damaged/rubbing or corroded wires? |
Fri May 20 2011 10:38pm |
ashleyandash Member Since: 18 Oct 2010 Location: Leek, Staffordshire Posts: 11 |
Thanks for the reply, do I need to do anything other than raise the suspension and inspect?
Sat May 21 2011 8:41am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
The connectors can be a struggle to undo - check that the upstream connector is still sound and the wires have not been disturbed in the swap over - sensor is rear right from memory (& front left) but you can see it anyway. The sensor closes a circuit until worn 'open' IIRC.... |
Sat May 21 2011 8:47am |
