Home > General > Suspension fault: Pressure increases too slow...
buckblue
2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
Recently after running the car for 2 or 3mins i get the yellow suspension warning on the dash
Range Rover Sport HSE V8 4.4L 2006 model
took it to the mechanic shop and on the computer screen it says:
C1A20-64: PRESSURE INCREASES TOO SLOW WHEN FILLING RESERVOIR.
signal plausability error
he's not the best mechanic with the best experience and he's claiming he needs to change the air supenion compressor unit and it will cost around $1,000
wanted to check if anyone has an idea about this or been through this before
Post #296266 Sat Apr 16 2011 10:08am
rockportpurple
hi
hi i have just had the same thing on my sport,
same symptoms and same steering wheel on the dash the only thing that cured it was a new compressor pump
as it took ages to pump up the vehicle
regards
clive
Post #299642 Mon May 16 2011 3:06pm
Sizzle TDV8
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
If the compressor can be heard running (trying to fill up the air reservoir) sometimes the fault can be the exhaust valve on the compressor block I believe. This will relieve pressure if stuck open so could be why its taking a long while to pressurise the reservoir. And a far cheaper repair.
Good luck. 2007 RRS TDV8 Stornaway Grey with lots of smiles..
2007 Audi A4 2.0T Cabriolet
Missing - 2008 Suzuki GSX-R 750
Post #299665 Mon May 16 2011 6:04pm
Bobby
C1A2064
Pressure Increase Too Slow When Filling Reservoir
 Compressor fault
 Reservoir pipe air leak
 Reservoir air leak
 Gallery pipe air leak
 Intake filter blocked/restricted
 Intake pipe blocked/restricted
 Air suspension intake silencer blocked/restricted
 Corner valve stuck open
 Pressure sensor fault
Refer to the guided diagnostic routine for this code on the approved diagnostic system.
Check the Air suspension intake pipe and silencer for blockage/restriction Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #299697 Mon May 16 2011 9:28pm
Sizzle TDV8
Bow down I knew Bobby would save the day Bow down 2007 RRS TDV8 Stornaway Grey with lots of smiles..
Post #299726 Tue May 17 2011 8:43am
