Home > General > Onyx wheels |
barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187 |
Try these http://wheelsworldwide.co.uk/wheels/onyx/onyx/hgs 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels. |
Sat May 07 2011 7:53pm |
TenBob Member Since: 01 Nov 2010 Location: North Posts: 138 |
Buster, I'm fairly certain the Dare NK1 alloy is the same as the Onyx (minus the Onyx stamp). And the Dares are loads cheaper of course |
Sun May 08 2011 9:43am |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 |
Thanks for that - I'm on it!! Cheers Laurence. |
Mon May 09 2011 9:32am |
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 |
Make sure you check the weight loads...... |
Mon May 09 2011 9:37am |
Excellent point - loads of ebay sellers in particular, flogging wheels that are not rated for 4x4 use, although their ads state otherwise... |
Mon May 09 2011 9:40am |
Understood! - thanks for the PM Cheers Laurence. |
Mon May 09 2011 10:20am |
http://www.rimstyle.com/products/detail/?c...120-E45l45
Mon May 09 2011 12:27pm |
It was mentioned on an earlier thread they should be 950kg minimum. I'd call the supplier and ask |
Mon May 09 2011 12:49pm |
Thanks TenBob I have made contact with supplier and he is coming back to me with load rating although he assures me that they are made for the RR's and will be correct! But no harm in asking - thanks for the heads up.
Mon May 09 2011 1:10pm |
I can see you an easter egg from our fridge and send you a certificate to say the foil is made of real gold!!!!
Mon May 09 2011 1:59pm |
800kg rated alloys are likely to bend/crack
No problems mate I recently backed out of an ebay transaction as the seller was flogging some wheels incorrectly rated. Pi**ed the seller off somewhat I have to say, but safer to have the correct rating! |
Mon May 09 2011 2:00pm |
Your right there!
Mon May 09 2011 6:54pm |
There you go viewers, for those of you that are thinking of upgrading to 22's, you learn something new everyday |
Mon May 09 2011 7:59pm |
Everyday's a school day! Buster, the best guide to alloy capacity is written on the back of original LR alloys |
Mon May 09 2011 8:24pm |
