![]() | Home > Technical > Detachable tow ball |
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 ![]() ![]() ![]() |
Just above the number "1" on the green plastic you will see a small metal roll pin, using a small punch (approx 2-3 mm diameter) punch the pin out and the old part will come off, reverse the procedure to fit the new part. Total time to change 5 minutes.
Your a star...thank you |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
replaced mine but the pin would not move, and it was stuck on the vehicle, so i just drilleds through the plastic handle, been carefull not to damage the centre, then ripped of with some large grips.
Thanks I'll go out in a bit to try |
Can you help me again...as i think i might be being particularily dense!
I have never had a problem fitting or removing the tow bar so I am a little surprised that you are having difficulty.
Thanks - its all working now, I opened the inspection cover (someone had been in it before and nearly rounded the head |
