Home > General > Did the problem in this thread ever get resolved??????
felstmiester
United Kingdom 2005 Range Rover Sport TDV6 HSE Santorini Black
I have just purchased a sport with the exact same problem. Judging by the photo's in this thread my load cover can't be a freelander one as its not that short.
http://www.rrsport.co.uk/forum/topic18811....load+cover
Post #297938 Tue May 03 2011 5:16pm
ChrisP
Perhaps you could just pop into your local LR dealer and see if your load cover fits OK in another Sport to check if that is OK first? MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #297944 Tue May 03 2011 5:46pm
felstmiester
Yeah i've got to take a trip to the dealer soon anyway but looking at the first pics of the one in the thread showing how short it is, that is exactly like mine looks, they then comfirmed that theye'd tried his in some other rrs's at the dealers and it fitted fine, and then went on to maybe his side trims had move appart a little causing this problem, but then the thread ends and they never got to the bottom of the problem.
Post #297947 Tue May 03 2011 6:01pm
BIG DJ
No it didn't.
I took it to LPR and they had a quick look and tried a new cover but the same. Wanted me to book it in to be looked at but I didn't take it in as I'll look my self when I get time rather than getting an almighty bill. They reckoned it was somthing to do with the side panels maybe being removed before.
Funny how there has been a few people with the same problem tho Exclamation
Post #298028 Wed May 04 2011 9:00am
felstmiester
BIG DJ wrote:
No it didn't.
Right! I got home from work today and spent some time in my boot. There is no way my trims either side have moved, if you was to pull the in to accomodate the length of the load cover there would be a gap between the windows and the trim and you would never fold the seats down.
it really is a mystery!
Post #298095 Wed May 04 2011 6:51pm
BIG DJ
Definately strange. Do you have a dog guard fitted?
Post #298101 Wed May 04 2011 7:30pm
felstmiester
nope! And its never had one fitted previously either. I have even taken the actual load cover to bits to see if something may of happened to make it shorter but there's no way that can happen either as there is no way anything can move as the pole inside determins the length and the end caps actually screw into the ends of the pole that the load cover is wound onto.
Post #298106 Wed May 04 2011 7:48pm
BIG DJ
I wonder if they are different in a later model.
Maybe they have been fitted with later model covers? Maybe James from LPR could check the part numbers on the system and see if there is different ones.
Post #298109 Wed May 04 2011 8:06pm
BIG DJ
Have pm'd James to see if he can check with parts. Will let you know of any result.
Post #298112 Wed May 04 2011 8:19pm
Lookers Park Royal
Big DJ,
Got your PM and have responded. In essence the cover is the same part now as it was at launch, therefore ruling out a change to the dimensions of the blind.
As said before, we're happy to have a look for you.
James Thumbs Up
Post #298156 Thu May 05 2011 11:08am
BIG DJ
Thanks James Thumbs Up
Post #298159 Thu May 05 2011 12:15pm
panda
Hi all
Just measured my load cover 56 hse that fits fine.
The main body of cover is 1350mm long with 10mm of spring clip sticking out each end 1370mm overall.
Hope this might help.
Post #298187 Thu May 05 2011 4:35pm
felstmiester
Yep! Mine is 1350 and 1370 inc spring clips, but it don't f Censored fit! Confused
Maybe a small few RRS's was made slightly wider than all the others lol. Cmon let all messure the width of the actual car lol.
Post #298216 Thu May 05 2011 7:06pm
SRE
Spain
Poss accident damage, shunted up the A Censored se. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #298280 Fri May 06 2011 9:03am
felstmiester
Just an update on this problem.
I went to my local lookers today in bishops stortford to ask about this load cover problem. The first fella i spoke to had nevar heard of it but went to get someone from the workshop to have a look and he said they had had a customer in with the same complaint and the way they rectified it was to fit two new left and right boot trims. He then went on to say that some how the trims must come of the production line slightly under sized, hence causing this problem. Surely if this is the case its down to land rover to rectify this problem but nooooo, he said it cost the customer close to £400 to solve this Shocked Shocked Shocked
Post #300948 Fri May 27 2011 11:51am
