![]() | Home > General > Did the problem in this thread ever get resolved?????? |
felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203 ![]() ![]() ![]() |
I have just purchased a sport with the exact same problem. Judging by the photo's in this thread my load cover can't be a freelander one as its not that short.
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
Perhaps you could just pop into your local LR dealer and see if your load cover fits OK in another Sport to check if that is OK first? MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
No it didn't.
Right! I got home from work today and spent some time in my boot. There is no way my trims either side have moved, if you was to pull the in to accomodate the length of the load cover there would be a gap between the windows and the trim and you would never fold the seats down. it really is a mystery! |
Definately strange. Do you have a dog guard fitted? |
nope! And its never had one fitted previously either. I have even taken the actual load cover to bits to see if something may of happened to make it shorter but there's no way that can happen either as there is no way anything can move as the pole inside determins the length and the end caps actually screw into the ends of the pole that the load cover is wound onto. |
I wonder if they are different in a later model.
Have pm'd James to see if he can check with parts. Will let you know of any result. |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
Big DJ,
Thanks James |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Hi all
Yep! Mine is 1350 and 1370 inc spring clips, but it don't f |
Poss accident damage, shunted up the A ![]() Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Just an update on this problem.
