Home > Technical > Slight tappin nose
Jimmy07
United Kingdom 2007 Range Rover Sport TDV6 HSE Bonatti Grey
Slight tappin nose
Hi I get at tappin noise sometimes when started then goes off when oil light
Goes off and doesn't do it again when started after it's cold start in a morning ever!
And also doesn't do it every cold start
Can anyone enlighten me ??
Regards
Post #297722 Sat Apr 30 2011 5:55am
barry15555
England 2006 Range Rover Sport Supercharged Bonatti Grey
Sounds like its time for a service, Have you checked your oil level. Question 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels.
Post #297741 Sat Apr 30 2011 9:18am
Jimmy07
Ye me thinks so having cambelt done next week gunner check oil level
Tomoz was serviced on just sort of 90 k and only got 98 on now sounds like tapets to me ??
Post #297757 Sat Apr 30 2011 4:45pm
BIG DJ
Mine does exactly the same. It's an 06 with only 30k on the clock and was serviced in January with little mileage since. Checked the oil level and all fine. Sending it to my mechanic next week to have a look!
Post #297788 Sun May 01 2011 8:43am
tornado34
2006 Range Rover Sport TDV6 HSE Zambezi Silver
Check out my post 'very poorly TDV6' - sorry haven't worked out how to post link Embarassed
Mine started off exactly like this, I actually decribed it to LR like the soucnd old tappets used to make.
Don't want to scare you, but get it checked ASAP - mine ended up costing almost £8000 and only had low mileage.
Keep the forum posted, would be interested.
- just for the record, my main stealer said they had replaced 'several' TDV6's with this problem - ouch!!
Post #298167 Thu May 05 2011 1:22pm
BIG DJ
Did it gradually get worse?
Post #298170 Thu May 05 2011 1:39pm
tornado34
Just started as I was driving at 60MPH ish and within 5 mins of driving became much. much worse. So much so that it sounded wrong and expensive! So came on very quickly on mine.
First thoughts were OIL OIL OIL, but all looked ok and dipped fine on stick. No leaks of anything under the car. It was driven onto the recovery flat bed and off at the main dealer and then it sounded very poorly.
I have heard (not sure if it's true) but this engine (used in other cars too) suffers from failure of the diesel injectors cooling system (not quite sure what that is) and as such leaks diesel / coolant / oil into the wrong place in the engine and destroys the engine. As I say, not sure if mine had this, but I heard this from a Peugeot technician who works on this enging in the 806 I think.
Post #298173 Thu May 05 2011 2:05pm
BIG DJ
Mine is only after starting for about 20 secs. Gonna flush the system and change oil filter and new oil and see if it's any better.
Post #298183 Thu May 05 2011 3:26pm
tornado34
Could be a good idea to completely flush and change filter to see if it solves the problem. If it does then it could mean contamination of the oil (and breakdown of oil performance), so it could be worth checking the injector cooling route, as this may be the source of the contamination - just a thought - I am no pro, just thinking logically
Post #298194 Thu May 05 2011 5:37pm
tornado34
Just for info, when LR replaced my engine they used;
Castrol SLX Professional Powerflow C1 5w-30 oil, just in case you want to be absolutely sure of the right oil spec Thumbs Up
Post #298195 Thu May 05 2011 5:40pm
Jimmy07
Not takin any chances just took new warranty out on my rrs covers all engine and gear box
Post #298202 Thu May 05 2011 6:11pm
